Calculating Focal Length of 1D Fresnel Lens
skrat
Calculate the focal length of 1D Fresnel lens, whose transmittance is given as $$T(\xi)=\frac 1 2(1+\cos(\alpha \xi ^2)).$$
Anything you wish
I have no idea. I tried to use the equation for diffraction image $$u_p=C\int _0 ^{R_p}T(\xi)e^{ik\frac{r^2}{2z}}rdr$$ which is simply a Fresnel diffraction multiplied with lens transmittance. I thought this would bring me to something useful, but I couldn't see how this would help.
Any ideas/hints on how to solve this problem would be highly appreciated!
Anything you wish
... nope, it's anything you choose ... part of the point of this section is to tell us how you are thinking about the problem. We already know how we are thinking of the problem.
I have no idea.
You could try looking at your notes - consider: what does the transmittance function tell you?
How would you use the transmittance function to work out how a plane wave would be affected?
... so you did have some idea - did you follow through on it?
Sometimes you won't be able to see how something will turn out until after you'd gone down the path for a bit.
Also see:
http://inst.eecs.berkeley.edu/~ee290f/fa04/Lenses_post.pdf
The problem is here:
$$u_f=C\int T(\xi)e^{i\frac{k}{2R}\xi ^2}d\xi=C\int \frac 1 2(1+\cos(\alpha \xi^2))e^{i\frac{k}{2R}\xi ^2}d\xi=$$ $$=C\int \frac 1 2 (1+\frac 1 2(e^{i\alpha \xi ^2}+e^{-i\alpha \xi ^2}))e^{i\frac{k}{2R}\xi ^2}d\xi=$$ $$=C\int[\frac 1 2e^{i\frac{k}{2R}\xi ^2}+\frac 1 4 e^{i(\frac{k}{2R}-\alpha)\xi ^2}+\frac 1 4 e^{i(\frac{k}{2R}+\alpha)\xi ^2}]d\xi$$
In in the focal point the intensity (which is ##\propto |u_f|^2##) should have a huge peak. And from the equation above I should be able to already see that. Yet I don't. I am confused because of the imaginary argument in my exponents. How do I in this case find out where the peak is? :/
You shouldn't be too concerned about this. These integrals are a variant of Gaussian integrals and they have the form:-
##\int_0^x e^{t^2}\ dt = -i\sqrt{\frac{\pi}{2}}erf(ix)##
where ##erf(ix)## is the error function.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
