How does friction affect snowboarding?
  • Thread starter Thread starter Mash
    Friction
Friction plays a crucial role in snowboarding dynamics, particularly when a snowboarder turns. The coefficient of friction varies in different directions, allowing for smooth sliding in one direction while stopping in another. A snowboarder can turn uphill until they lose momentum, but stopping occurs when they allow the board to slide instead of carving. The angle between the snowboard's orientation and its velocity affects the friction experienced. Understanding these principles can enhance the design of snowboarding simulations and gameplay mechanics.
Mash
Hi,
I am trying to make a simply model of a snowboarder for a computer game.
I have implemented basic friction, he slows and comes to a stop when the acceleration force is less than the frictional force.
I am now puzzled as how friction changes when the snowboarder turns. As the snowboarder turns 90 degrees on a hill, he comes to a complete stop also, and does not slide down the hill sideways. Why is this? What prevents a snowboarder from snowboarding uphill?
Any help/discussion would be handy
Mash
The acceleration is just gravity (not the person, hence snowboarders go downhill). The key concept would be that the coefficient of friction is different in orthogonal directions. A ski is deliberately shaped to slide smoothly over snow in one direction, but plough to a stop in the the other.
(This really only belongs in the general physics forum, what's with the double-posting?)
A snowboarder can most certainly snowboard uphill in a turn until they run out of momentum. What prevents it when they stop is that they let the board slide instead of biting and carving out the turn.
Ahhh, so the coefficient changes... that makes things simpler. Oh yes, I thought that it should have been in classical physics (mechanics) after i already posted under general. Sorry bout that.
Would it be fair to say that the coefficient increases as the angle between the acceleration and the direction of the snowboarder increases?
Oh right. Is it possible to do a complete 360 degree turn going up the hill then back down if you had enough speed? Or is there some sort of bound on how far you can travel uphill...
No. What matters is the angle between the snowboard and its velocity. You would have sliding friction along one axis, and normally static friction along the other (it works like a roller-skate). And actually it seems to be that axis that moves due to board deformation as the person leans, to steer. You know, one could do a snowboarding simulation that begins right from the design (and characterisation) of the board..
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
