Friction - exists in a vacuum?
  • Thread starter Thread starter tiwai016
    Friction Vacuum
Friction can occur in a vacuum, contrary to the assumption that it cannot. While a vacuum removes air resistance, friction still exists between solid surfaces, as demonstrated by the operation of trains in vacuum tunnels, which can achieve higher speeds due to reduced air friction. Research indicates that under certain conditions, such as cold welding and galling, friction can increase significantly in a vacuum, especially with materials like titanium. Tests show that when surfaces are displaced under load, the friction can increase nearly tenfold in a vacuum compared to an atmosphere. Understanding these friction properties is crucial for applications in space and advanced transportation systems.
tiwai016
friction -- exists in a vacuum?
Is it possible for friction to take place in a vaccum?
Sure. Kind of hard to walk on the moon without friction, eh? :smile:
With vacuum you actually take away only few ways of friction the main being that of air and a object moving through it.
They had a plan to build special vacuum tunnels with high speed trains in them, train has very little friction as it is rolling on metal wheels on metal track , and if you remove the air you can increase the speed significantly.
Nuts and bolts still work on the outside of the space station.
Under certain conditions cold welding and/galling can occur as what this paper has concluded from the THE GALILEO HIGH GAIN ANTENNA DEPLOYMENT ANOMALY.
http://trs-new.jpl.nasa.gov/dspace/bitstream/2014/32404/1/94-0141.pdf
A series of tests was performed at NASA 1.cwis Research Center on the friction
properties of drylubed and bare titanium against ]nconcl 7 18.[31 The results of these tests
showed that if the (WO surfaces arc displaced relative to each other under load and in air, then
clisplacccl relative to each other under load in a vacuum, the sliding friction between the
surfaces increases nearly ten times, When a drylubcd and anodized pin was operated in an
atmosphere, the drylube surface was quickly destroyed and, as a result, exposed the base
titanium, The testing also showed that with an atmosphere present to continue to react with
the bare titanium as it was worn by sliding contact, the friction coefficient never exceeded
0,35. However, once a pin’s drylubc was damaged by operation in air and then operated in a
vacuLIm, the surfaces started to gall and produce cmfficients of friction in excess of 1.0,
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
