Friction Force: Why do we walk?
The discussion centers on the mechanics of human walking, specifically the forces involved in the process. When a person pushes against the ground (force Fp), static friction acts in the opposite direction, allowing forward movement as long as Fp is less than or equal to the maximum static friction (Fsmax). Participants clarify that the foot must remain anchored to the ground for walking to occur, and pivoting the torso helps in changing the body's center of mass, facilitating movement. The conversation also touches on the importance of static friction in generating forward motion and the role of body mechanics in walking dynamics. Ultimately, the participants emphasize the interplay of forces and body positioning in understanding how humans walk.
babaliaris
I created this example to see if i can explain how humans walk but I can't. If I'm correct, when we push the ground to move forward we apply a force with the opposite direction (backward). Let's name this force Fp (for push). Because of that force, a friction force is being applied to us with the opposite direction of Fp (forward). While |Fp| <= |Fsmax| , we don't move at all. At some point |Fp| > |Fsmax| so we should slide (move) backwards and then Fs will be Fk (kinematic Friction).
Then why in the real word we move forward? Am I missing something here? Please consider that I'm new in Physics.
Likes Delta2
babaliaris said:
I created this example to see if i can explain how humans walk but I can't. If I'm correct, when we push the ground to move forward we apply a force with the opposite direction (backward). Let's name this force Fp (for push). Because of that force, a friction force is being applied to us with the opposite direction of Fp (forward). While Fp <= Fsmax , we don't move at all.
That sounds wrong. The static friction is between the bottom of your shoe and the ground. So this case is normal walking without your feet slipping. Why do you say you wouldn't move at all?
Likes babaliaris and Delta2
No, that's when we move. What doesn't move is the foot.
We move by pivoting our torso on our legs. The leg has to be anchored on the ground - i.e., not sliding, i.e., Fp <= Fsmax. The thing that moves is the torso.
Put a person on slippery ice, and the torso does not move because the leg is not anchored.
That explain's it perfectly! Thank you!
Just put in a different way, what is the total force on our body when we walk (assuming we don't touch anything with our hands)? Since our weight is canceled by the normal force, all that is left is the force of static friction between our foot and the floor(Fp is the force from our foot to the floor, this force is acting upon the floor, not upon us).
The force of static friction is what put us in motion, contrary to the usual case, where we are used to have static friction to try to oppose the motion of an object.
Likes babaliaris
Also i noticed that when i walk and pivoting my torso forward's I move faster than when it's straight. This is because I changed the direction of my weight and now $$Fg_{x}$$ becomes greater than 0?
So in other words, because of the static friction you have the ability to anchor your foot on the ground. By anchoring your foot, you can pivot your body and change the direction of your weight and now its your weight that creates the force that accelerates you and you move. If you pivot forward you accelerate forward, if you pivot backwards you accelerate backwards. This force is $$Fg_{x}$$ where normally if you stand straight is 0. OMG I LOVE PHYSICS!
I don't think that you can change the direction of your weight, you can only change the centre of mass of your body. I think what you do is that you increase the normal force by pressing the ground harder, so that increases the static friction from the ground to body, so greater force from the friction means greater acceleration, cause as I said, the force of static friction is the only force that remains on our body and is what put us in motion.
Post #7 #8 are wrong you are right... You can't change the direction of weight lol what i was thinking, once again I'm overthinking:-p:-p:-p
babaliaris said:
Post #8 is wrong you are right... You can't change the direction of weight lol what i was thinking, once again I'm overthinking:-p:-p:-p
Not completely wrong, you might not change the direction of weight, but after thinking it abit more carefully myself, I think what you change is the direction of ##F_p##. Do you agree?
Likes babaliaris
Yes!
As far as I can see, nobody addressed [correctly] the real error here:
A free body diagram includes all of the forces acting on a body. Fp is a force you apply to the ground. It should not be on your diagram. Now what is left is one horizontal force, pushing you forward.
Likes CWatters, babaliaris and Delta2
I think I say it inside the parentheses in post #6.
Likes babaliaris
Lol you are extremely right! Fp is being applied to the ground not to your foot! And according to Newton's third law, the ground must also apply a force to you and this is the friction force, this is why you move forward!
Likes Delta2
LoL didn't see that :-p:-p:-p
e hehe lol :smile::-p:smile:
If the OP is able to visit San Francisco, California; I recommend a trip to Frank Oppenheimer's Exploratorium https://www.exploratorium.edu/ .
Along with many fascinating exhibits including a rendition of Foucault's Pendulum demonstrating the Earth's rotation, you may find a small interactive model of the human torso, legs and feet. A visitor can study the sequence of nerves and muscles that produce bipedal walking by pressing a sequence of switches simulating the electro-chemical impulses from the brain. Anecdotally it appears that adult visitors tend to over and under control the sequence while young humans quickly master the non-intuitive series of electrical impulses required for smooth gait and (simulated) forward motion. A wireless "docent" explains the physics of bipedal motion.
If the OP still searches for models to simplify walking physics, consider using thrust to model the motive force coupled with torque to simplify the moment vectors through the human body. A more advanced walking model might include swinging arms and even head angle as center of gravity (COG) varies with gait and stance.
As suggested in an earlier post, abandoning the requirement for friction between the foot and ground to produce momentum, say on smooth ice, provides deeper understanding of how altering body COG and manipulating torque provides both forward and angular momentum. Examine limb movements of ice skaters, for example. Very low drag (friction) and controlled stance yields amazing motion. Going beyond simple COG to recognize moment arms, understand how a spinning skater alters their angular momentum by extending and contracting their limbs.
Isaac Asimov and other science writers have described bipedal walking as "controlled falling". There are studies available online where actors wear suits equipped with reflective devices ("dots") while performing various human motions such as walking, running, dancing, etc. within range of cameras and motion sensors.
Likes babaliaris
I live in Greece...
babaliaris said:
I live in Greece...
Does that affect your floors like this?
Likes Klystron
Haha no
If you get the pleasure of watching a child walk for the first time you will see what happens.
They (unexpectedly) lean forward and are in danger of falling, as they often have. This time they move one foot forward to stop the fall, then when the "almost fall" continues, they bring their other foot forward, and repeat - with a broad smile on their face. That does not explain the Physics of walking, but does give an insight into the joy of walking.
Likes babaliaris
