- #1
jemma
- 36
- 0
I want to copy and paste a very large equation from Mathematica into MathType in Word however MathType is saying my equation is too large. I need to do this for supplementary info for a publication. Any ideas?
jemma said:I want to copy and paste a very large equation from Mathematica into MathType in Word however MathType is saying my equation is too large. I need to do this for supplementary info for a publication. Any ideas?
"From Mathematica into MathType" is a feature that allows users to transfer mathematical equations and expressions from the Mathematica software into the MathType software. This allows for easier editing and formatting of equations for use in documents, presentations, and other materials.
To use "From Mathematica into MathType", first open the Mathematica notebook containing the equation you want to transfer. Then, select the equation and go to the "File" menu. From there, select "Save as Special" and choose "MathType Equation" as the file type. This will save the equation in a format that can be opened and edited in MathType.
Yes, you can transfer multiple equations at once using "From Mathematica into MathType". Simply select all the equations you want to transfer before following the steps mentioned above. This will save all the equations as separate MathType files.
"From Mathematica into MathType" is compatible with Mathematica versions 3.0 and higher, and MathType versions 3.0 and higher. However, some features may not be available in older versions of either software.
Yes, you can edit the equations in MathType after transferring them from Mathematica. This allows for further customization and formatting of the equations for your specific needs.
