What factors affect fuel consumption and speed in road vehicles?
Fuel consumption during a journey is influenced by the speed of the vehicle, with instantaneous fuel consumption being proportional to engine power. The discussion focuses on comparing fuel usage at two constant speeds while ignoring rolling resistance and only considering air drag. The total fuel used is calculated using the formula of power multiplied by time. For those interested in deeper insights, the book "Road Vehicle Performance: Methods of Measurement and Calculation" by George Gordon Lucas is recommended, specifically volume 7. Understanding these factors is crucial for optimizing fuel efficiency in road vehicles.
dean barry
I was wondering about the amount of fuel used for a given journey.
My model is that the same journey is made at two different constant speeds
I have assumed that instantaneous fuel consumption is proportional to the power produced by the engine at that point.
I an ignoring rolling resistance losses, and considering air drag only.
I have used power * time as a base for total amount of fuel used for each journey
Any comments ?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
