What does the function machine do with numbers 1, 2, 4, and 7?
  • Thread starter Thread starter nonstop
    Function Machine
The discussion revolves around a function machine that transforms the numbers 1, 2, 4, and 7 into 4, 8, 16, and 28, respectively. The transformation appears to be a scaling of the input numbers, specifically a function defined as f(x) = 4x. There is also a mention of a binary state machine perspective, suggesting a left shift operation, but this is less relevant to the main function. The conversation highlights that specifying a function at only four points does not fully define it, yet for practical purposes, the scaling factor can be considered constant. Overall, the function machine's operation is primarily understood as a simple multiplication of the input by 4.
nonstop
If we have function machine, which change numbers 1,2,4 and 7 like this
1 --> 4
2 --> 8
4 --> 16
7 --> 28
How i know simple, what is function, what machine use? :frown:
( I don't speak very well english )
Mathematics news on Phys.org
From a numerical perspective, it looks like a straightforward scaling of the input number to get the output number (question -- what is the scale factor?).
From a binary state machine perspective, it looks like a shift left by a constant number of bits. How many bits?
Machine? What are you talking about? Specifying a function at only 4 points does not specify the function, but for simple purposes you can consider the function to be a constant multiple of the input.
what did you mean by that question? can you please elaborate?
What about:
f(x)=4x
As:
<br /> f(1)=4<br /> f(2)=8<br /> f(4)=16<br /> f(7)=28<br />
What lo2 said with a domain of {1,2,4,7}
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
