B What is the function rule for f(x,y) in terms of s and t?
  • B
  • Thread starter Thread starter beaf123
    Function Rules
beaf123
<Moderator's note: Moved from homework forum for the general question what it means. For the saddle point question, please re-post it in the homework section, but show us some effort and where you stuck.>[/color]
I have been given that
and that
Then I am asked to show, by contradiction, that the point (0, 0) is a saddle point for f.
First my problem is that I have never seen that w is a function x and y in the first equation and a function of s and t in the second equation. How can I insert the second equation into the first?
I am not sure if I have provided enough information, but scream out if you miss something.
This is essentially just composing functions. For example if you have ##f(x)= x^{2}## and ##g(x) = \cos{x}## then ##f(g(x)) = \cos ^{2}{x}##. Here of course there are two variables involved and the functions are a little bit more complicated.
and that
Just replace ##s## by ##x^2## and ##t## by ##x y^2## when you write the formula for ##w(s,t)##.
There are essentially two ways of doing this problem.
(1) Make the replacements above and then deal directly with the function ##f(x,y)## in all its gory detail.
(2) Use the chain rule:
$$\frac{\partial w}{\partial x} = \frac{\partial w}{\partial s} \frac{\partial s}{\partial x}
+ \frac{\partial w}{\partial t} \frac{\partial t} {\partial x}, $$
etc.
Method (2) gets increasingly messy when we go to second derivatives, so if I were doing it I would use Method (1).
##w## is a function. Full stop. ##x, y, s, t## are all dummy variables. You could replace them with any other symbols you like.
Likes K Murty
and that
You write ##w(s,t) = t \cdot (e^{rs} - rs - 1)##.
Is that accurate, or does it contain a "typo"? That is, do you just have some other parameter ##r## involved in the definition of ##w##---exactly as you wrote it---or should the ##r## on the right really be ##t##?
Likes PeroK
Thank you fro your answers. I tried to do it with (1) Make the replacements above and then deal directly with the function f(x,y) in all its gory detail. And hopefully I did it right.
It is provided that r>0, so it is just a constant.
