I Fundamental Forces: Electromagnetic, Gravity, Strong & Weak Interactions
The four fundamental forces are electromagnetic, gravity, strong, and weak interactions. While Newton's law of gravitation is less effective than Einstein's general relativity, gravity is now described using the energy-stress tensor. The Coulomb force, analogous to gravity, is explained by Quantum Electrodynamics (QED), but it is not a new theory. There are ongoing discussions about string theory's potential to unify these forces, although it currently lacks experimental evidence. Gravity is fundamentally different from the other forces, understood through the geometry of space-time, while the other forces are described by quantum mechanics and field theory.
Mayan Fung
As far as I know, we regard the electromagnetic force, gravity, strong and weak interactions as the four fundamental forces.
We know that Newton's law of gravitation does not perform as well as Einstein's general relativity. Scientists are now using energy-stress tensor to describe gravitational fields. Here comes my question: How do we interpret the other three forces? I am more familiar with the EM interaction. Let me focus on it.
When I first learn the Columb Force, my teacher told us that it behaves just like gravitation - both decay inverse squarely. Now, we have a new theory explaining gravity. Do we have a new theory for Columb force? I read some articles saying that string theory is trying to do this. My main concern is: do we find any inconsistency between experiments and our Columb Force theory, just like the case of Mercury's precession?
I look forward to your comments and opinions!
Yes.
Hmm, yes and no :smile:, it's not a new theory. It is called Quantum Electrodynamics (QED). And it is not like general relativity.
See these links on HyperPhysics:
and, if you are interested
Please note that there are no experimental evidence (yet) for string theory :wink:.
Likes Mayan Fung
The comparison of the Coulomb force and gravity is for teaching purposes only - it's a handy analogy for givig students a loose feel for electrostatic forces. The two are not considered anything alike IRL.
At some point in those lessons, the analogy should break.
We understand the "other three" forces in terms of quantum mechanics and, specifically, field theory... in this picture, the forces are the result of interactions with fundamental particles whose behaviour is described using probability and statistics. The particles themselves appear as small fluctuations in the overall field.
We understand gravity as a pseudoforce arising from the geometry of space-time.
However - there are fundamental disagreements between quantum mechanics and general relativity which remain unsolved.
String theory is a work in progress that attempts to do this, or, at least, tries to find out what such a solution may look like.
You will also see references to "quantum gravity" which attempts to treat gravity like a quantum mechanics force.
Likes Mayan Fung
Wow, your comments are awesome! Can I say gravitation is somehow different from the other three forces?
At current state of knowledge it is fair to say that gravity is understood in a quite different way to the other forces.
Likes Mayan Fung
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
