dirad
- 16
why are many fundamental laws of nature formulated in the form of differential equations?
Adyssa said:If you measure something, or some group of things, every day for a year, then you have a bunch of data. You can plot the data on a graph, measurement vs time, and draw a curve through the points, or rather, find a function that determines the curve. Then you can "do calculus" and determine the rate of change at any point on the curve. So you might measure the rate of change of the number of frogs in your front yard. Or the rate of change of temperature, or clouds, or, if you're patient, trees. Calculus just happens to be the language we use. It gets complicated when things depend on many other things.
dirad said:if i plot data on a graph and draw a curve, then i have the required variables. so, why calculate a rate of change?
dirad said:why are many fundamental laws of nature formulated in the form of differential equations?
DeIdeal said:Well, because there are things that depend on the rate of change
Things which we usually model with differential equations! We can do measurements to confirm and/or come up with these models, and then use these models to predict behaviour of different systems.
jackmell said:In particular, second-order differential equations. But laws we design describe phenomena in Nature and Nature is a changing phenomenon, our Universe is a dynamic (changing) system. Planets are revolving around stars, stars change, life changes. Differential equations is a math of change: the derivative is a change-descriptor, it describes change. So not surprisingly, creating laws to describe Nature would work well in the language of Differential Equations.
dirad said:then, i am modelling with differential equations. these equations have solutions where every thing is straightened out and we have no rates of change but we have the total change. why do we not use these solutions for modelling systems?
DeIdeal said:Could you post an example of what you mean? If I get what you mean, solutions like that usually only work in very specific situations, whereas the model works in a more general one.
dirad said:s=1/2 at2 where s= displacement of falling body, t= total time, a= acceleration due to Earth gravity
DeIdeal said:Good, that's what I guessed you we're talking about. It's, as I assume you already know, derived from Newton's m\ddot{r}=F. But, and this is the big thing, it only works when F, the force, is constant (for free fall F=-g~9.8 m/s2), and the initial velocity of the object is zero.
Now, what would you do if F=-kr and the system is the (in)famous harmonic oscillator? The differential equation we use to model the system still works (as long as we're satisfied with the classical approximation), but the solution is very different. This is why the models are often more important than their specific solutions, and the models are often differential equations.
dirad said:thanks. this gets us back to first question. basic laws like Newton's 2nd law are differential equations containing derivatives. the same goes for maxwell's ,schroedinger's,einstein's equations. is there some general solution to each of these equations that can be considered as fundamental law in its own right?
SteamKing said:Because not everything in nature is static. Some things depend on the rate of change of other things, to be hand-wavingly vague about it.
dirad said:using diff.eqs.contain some hidden assumptions. we assume continuity and smoothness of variables, for example. we associate simultaneous cause (force) and effect (acceleration). why do we almost automatically resort to them ?
Because sometimes quantitative things change and their changes are often parametrized by ##n## variables. For some reason, everyone wants to find out about things that change.dirad said:Why are many fundamental laws of nature formulated in the form of differential equations?
But...why? Is this always true?dirad said:s=1/2 at2 where s= displacement of falling body, t= total time, a= acceleration due to Earth gravity
Because many of the quantities in physics are defined in terms of various kinds of derivatives. There's really nothing deep in this. Calculus is simply necessarily to describe said physical quantities, algebra isn't enough.dirad said:why are many fundamental laws of nature formulated in the form of differential equations?
