I created this thread as well:
https://www.physicsforums.com/showthread.php?t=107565&highlight=wings+lift
Is lift essentially created because of higher pressure at the bottom of the wing compared to the top of the wing, causing a postive net upward force?
Yes, when generating lift, the pressure below is higher than the pressure above.
And the difference in pressure is created from lower wind or fluid speed at the bottom of the wing compared to the top of it, achieved by the unique shape of the wing?
No, lift requires an effective angle of attack to accelerate air downwards, a flat board will generate lift. You can stick your hand out the window of a fast moving car and angle it so it produces lift. The unique shape of the wing just improves the lift versus drag ratio for an intended range of air speeds and wing loadings. In some cases, like civilian aircraft, efficiency is traded off for ease of manufacturing, which is why near flat bottom wings are used so often.
The speed of the air is relative to a frame of reference. Relative to the surrounding air, the air above a wing is traveling slower than the air below it.
As already mentioned, lift occurs because air is accelerated downwards, and the total force is simple force = sum of the mass of air molecules affected by a wing passing by, times the average acceleration of each air molecule.
At moderate AOA (angle of attack) even for a flat board, most of this downwards acceleration occurs from above the wing.
A simple explanation is that as a wing passes through the air with a moderate AOA, it deflects air downwards from below, and introduces a void as it passed through the air from above. This mostly downwards moving void creates a low pressure area that draws air towards it from all directions, except air can't flow upwards through the wing, so there's a net downwards acceleration of air towards this moving void.
Since the pressure above the wing is lower than the pressure below the wing, some of the air stream is "stolen" by the low pressure area, lowering the separation point of the air stream in front of the wing. This reduces the amount of air flowing below a wing, and adds some downwards component to the lower stream so that the wing has less deflection to do. The air that moves upwards from the separation point had to be accelerated downwards even more to fill in that void from above the wing, and this requires even more air from further above to help "push" the air into that sucking void. These are the main reasons that most of the downwards acceleration of air occurs from above a wing, even in the case of a flat board, as long as AOA is not extreme.
Getting back to air speeds above and below a wing, the speeds are different because air is being accelerated towards the low pressure area, and away from the high pressure areas. The speeds aren't constant either, but instead, the air is being accelerated, towards low pressure areas, and away from high pressure areas.
The classic Bernoulli theroem is a case of conservation of energy. The total engergy of a volume of air is it's kinetic energy (which is frame of reference relative), pressure, and temperature. A wing passing through the air peforms work on the air, accelerating the air mostly downwards and some forwards, and therefore it's changing the kinetic energy of the air. Using either the air or the wing as a reference, the downwards flow represents an increase in kinetic energy. Relative to the air, drag flow represents an increase in kinetic energy, and relative to the wing, a decrease.
The most efficient airfoils used for gliders have curved upper and lower surfaces. If you draw a line from the leading edge the the trailing edge of a cross section of a wing, where the line is in the middle of the wing (equi-distant from upper and lower edges), the (downwards) curvature of this line is called camber. Gliders, both full scale and high end models is where most of the work in wing design is done these days. Wings are described as a basic airfoil shape, (the basic shape independent of camber), the thickness (% of the thickest part compared to the chord (distance from leading to trailing edge)), and the camber.
If you refer to the thread I posted, I included quite a few links on this subject.
