Gain margin - control and automation
Gain margin indicates how much the open loop gain of a control system can increase before it becomes unstable, with a negative gain margin suggesting potential instability. Although the controller gain is fixed post-design, variations in the plant parameters can impact the overall system stability. Factors such as AC mains voltage fluctuations and maintenance schedules of components like motors can alter these parameters during operation. This highlights the importance of designing controllers to accommodate potential uncertainties in the plant. Understanding these dynamics is crucial for maintaining system stability in real-time operations.
LM741
hi alll!
just a quick one.
You know when you design a controller - you go and plot the open loop transmission, L(jw) on a nichols plot, where L(jw) = C(jw)H(jw) P(jw)
where P and C are the plant and controller respectively. You then 'manipulate' this plot (i.e. vary your controller) until your design specs are met. My question is once you have a gain margin - what does this actually tell us - say we have gain margin of -5dB.
does this tell us that our controller gain can only increase by 5dB before the system bcomes unstable (assuming the system was already stable).
The thing i don't get is that our controller gain is fixed and doesn't change after we design it! so which gain (the controller or plant or H(hw) ) does the gain margin put a limit on?
think i might be missing something...
thanks!
If the gain margin is 5 dB, this means the open loop gain of the system can only increase by 5 dB before going unstable.
Your controller gain may not change, but a change in the parameters of the plant will throw everything off.
Basically, the higher the gain margin, the less likely a change in systems parameters will affect stability.
ok - cool - but these 'parameters' of the plant - what exactly are these and do they keep changing whilst the system is operating? SO the characteristics of the plant CAN change whilst it is operating?
This isn't plant uncertainty is it? - which is why we need a controller to compensate for this uncertainty?
think I've got it - if you could just confirm.
thanks
Anything that varies the transfer function can affect your gain (or phase) margin. Like, the AC mains voltage changing within tolerances in the plant will affect the startup time of AC motors. And where the motor shafts are in their periodic maintenance lubrication schedule will affect startup and operating speed under load.
thanks
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
