- 2,168
- 193
Are galaxies are really moving away.Or galaxies are stationary but space-time expends so galaxies move with it ? Or maybe they could be same thing ?
This is a coordinate dependent statement. In "local" normal coordinates, galaxies are certainly moving away.phinds said:Google "metric expansion". There is no (well, very little and for a different reason) proper motion of far distant galaxies with respect to the Earth, it's metric expansion.
Orodruin said:This is a coordinate dependent statement. In "local" normal coordinates, galaxies are certainly moving away.
Take a rubber belt and put 5-6 balls on it as if it's a kind of bead. Then pull the belt in opposite directions. You'll see the process itself.Arman777 said:Are galaxies are really moving away.Or galaxies are stationary but space-time expends so galaxies move with it ? Or maybe they could be same thing ?
acidmatic said:Take a rubber belt and put 5-6 balls on it as if it's a kind of bead. Then pull the belt in opposite directions. You'll see the process itself.
Scientists use a variety of methods to determine the movement of galaxies, such as measuring the redshift of light from galaxies and observing their trajectory over time.
Galaxies can be influenced by a variety of factors, such as the gravitational pull of other galaxies, dark matter, and the expansion of the universe.
No, the speed at which a galaxy moves depends on its location, size, and the forces acting upon it.
Yes, galaxies can collide and merge with each other due to their gravitational interactions. This can result in the formation of new galaxies.
The movement of galaxies plays a crucial role in the evolution of the universe. It helps to shape the structure of the universe and influences the formation of stars and other celestial bodies.
