ZapperZ said:
Wait, back off a minute. How do you "ionize electrons"??!
Zz.
How about - remove them from atoms and molecules, by fair means or foul?
But there are various possibilities.
A photon might undergo a Compton scattering off an electron that is effectively free, weakly bound to the outskirts of an atom.
In this case, the speed of the nucleus would be unaffected, because the nucleus would be a mere spectator that suddenly discovers its electron missing.
The angular distribution of the electron would then be given by Compton scattering - it would be impossible for the electron to travel towards the origin of the photon (because the photon is losing momentum and energy, not gaining).
On the other hand, imagine that a photon excites electron and nucleus as an atom.
In this case, the momentum of the electron would be balanced by the momentum of the recoil of the nucleus. The momentum of the photon would be irrelevant, and the electron could travel in any direction including towards the origin of photon.
So which of these processes would happen?
Or would both processes happen, but in every case just one or the other?
Or would a process of intermediate nature happen, where the nucleus/cation does receive some momentum, but the momentum/direction of the photon still matters?
Now, in every case, the electron ends up being much faster than the cation - whether the electron has equal momentum but higher energy, or whether the cation does not get momentum at all.
Am I right in guessing that the electron also travels further than the cation, before it is slowed down and captured into an anion?
Now, say imagine that the gamma rays are confined into a narrow ray.
Whether they undergo Compton scattering (whereby the electrons are emitted preferentially towards the ray, but can be emitted some angle to the side as well) or atomic ionization (wherby electrons are emitted in all directions), the electrons can leave the beam and many do, but cations due their small or no speed remain in or near the beam at first.
If the beam is weak then the effects of the beam are negligible. The cations stay where they are created in the beam, until they slowly diffuse away by Brownian motion. The anions also stay where they were created by stopping electrons, until they slowly diffuse and happen to meet the cations.
The beam thus creates a positively charged beam (of cations left behind by ionization) and a negatively charged shell (of anions from the stopped electrons). And also an electric field between the beam and the shell - inside the shell. Beam and shell together are neutral, so no electrostatic field outside the shell - in case of isotropic atomic ionization.
But if the ionization is at least partly from Compton scattering, then the electrons preferentially travel in the photon travel direction.
The negative shell is then displaced from the positive beam interior along the beam axis.
And this could create electrostatic field observable outside the shell.
Now, if the beam is strong, then for one the electrostatic fields would affect the ion behaviour appreciably. The cations would not only undergo free thermal diffusion out of the beam, but would also be propelled by electrostatic field to actively drift outside the beam. And the anions in the shell would actively drift towards the beam. Also the heating by the beam would cause the air and ions in the beam to expand, and then start to travel buoyantly in the direction that is up.
So... any comments on how the electrons would mainly be enitted, or what the electrostatic fields would look like? What would be the size of the shell?
