Gauge Invariance of the Schrodinger Equation
The discussion revolves around the gauge invariance of the Schrödinger equation, specifically examining the implications of gauge transformations on the equation and the behavior of the wave function under these transformations. Participants explore the mathematical relationships and properties of the operators involved in the context of theoretical physics.
  • One participant presents the Schrödinger equation and proposes transformations for the potentials and wave function, questioning the validity of simplifying the operator acting on the transformed wave function.
  • Another participant asserts that the exponential factor in the transformation commutes with operators, suggesting that the simplification is valid.
  • A different participant challenges the initial assumptions, pointing out potential sign mistakes and clarifying the gauge transformation of the electromagnetic field.
  • Further discussion ensues about whether the simplification of the operator acting on the wave function can be justified without additional calculations.
  • Some participants express uncertainty about the necessity of showing the validity of the simplification, while others encourage applying the same reasoning used in earlier steps.
  • One participant ultimately resolves their confusion, indicating a personal understanding of the topic.
Participants do not reach a consensus on the necessity of demonstrating the simplification of the operator acting on the wave function. Some believe it is trivially true, while others seek further clarification on the reasoning behind it.
Participants reference specific mathematical forms and transformations, indicating that assumptions about the nature of the wave function and the gauge transformations are critical to the discussion. The discussion also highlights the complexity of handling operators in quantum mechanics.
Diracobama2181
TL;DR
Find in a quick way to prove gauge invariance without entailing a ton of messy math
Given the Schrödinger equation of the form $$-i\hbar\frac{\partial \psi}{\partial t}=-\frac{1}{2m}(-i\hbar \nabla -\frac{q}{c}A)^2+q\phi$$
I can plug in the transformations $$A'=A-\nabla \lambda$$ , $$\phi'=\phi-\frac{\partial \lambda}{\partial t}$$, $$\psi'=e^{-\frac{iq\lambda}{\hbar c}}\psi$$
$$-i\hbar\frac{\partial \psi'}{\partial t}=(-\frac{1}{2m}(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)^2+q\phi-q\frac{\partial \lambda}{\partial t})\psi'$$.
Now when act on $$\psi'$$ on the right hand side, I come across the term $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)^2\psi'$$
I now that $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)\psi'=e^{-\frac{iq\lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)\psi$$, but can I just say that $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)^2\psi'=e^{-\frac{iq\lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)^2\psi$$, and if so, why? (In other words, is there a reason why I could simply do this twice rather than multiplying everything out, which gets messy). Thanks.
Why not? Your exponential factor is just a number, and it commutes with every operator inside the parentheses.
The exponential is not just a number, because ##\lambda=\lambda(t,\vec{x})##. The problem with #1 is the gauge transformation of the em. field and several sign mistakes. The SGE reads (with ##\hbar=c=1##)
$$\mathrm{i} \partial_t \psi = -\frac{1}{2m} (-\mathrm{i} \vec{\nabla}-q \vec{A})^2 \psi + q \phi \psi.$$
Now you make
$$\psi'=\exp(\mathrm{i} q \lambda), \quad \vec{A}'=\vec{A}+\vec{\nabla} \lambda, \quad \phi=\phi-\partial_t \lambda.$$
Then ##\psi'## with the potentials ##\phi'## and ##\vec{A}'## fullfills the same SGE as ##\psi## with the potentials ##\phi## and ##\vec{A}##, i.e., the physics is invariant under gauge transformations, because ##\psi'## differs from ##\psi## only by a phase factor and the potentials only by a gauge transformation, which doesn't change the physical fields ##\vec{E}## and ##\vec{B}##.
I know it is gauge invariant. I suppose it is not clear the issue I am having. I know it is the case that
$$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)\psi'=e^{-\frac{iq\lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)\psi$$.
I want to know if it is trivially true that $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)^2\psi'=e^{-\frac{iq\lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)^2\psi$$. In other words could I simply just say that the operator $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)$$ acts on $$\psi'$$ twice., or do I need to show that $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)e^{-\frac{iq\lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)\psi=e^{-\frac{iq\lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)^2\psi$$?.
If you understand why the first equation in your post #4 holds, it should be obvious that also the last equation holds. I am not really sure what you want to shortcut here...
You don't need to do anything more to "short cut". If the 1st. equation in #4 holds for all (sic) functions ##\psi##, then the 2nd equation follows immediately without any further calculation.
Perhaps it is a silly question. I was just wondering why it held. Thank you.
Well, did you go through the logic that leads to the first equation? Can you apply the same reasoning with ##\Phi = (-i\hbar\nabla - q/c A)\Psi## as a the function?
So $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)\psi'=(-i\hbar \nabla e^{-\frac{iq \lambda}{\hbar c}}\psi -\frac{q}{c}Ae^{-\frac{iq \lambda}{\hbar c}}\psi+\frac{q}{c}\nabla \lambda e^{-\frac{iq \lambda}{\hbar c}}\psi)=(-\frac{q}{c}\nabla\lambda e^{-\frac{iq \lambda}{\hbar c}} \psi-i\hbar \nabla\psi e^{-\frac{iq \lambda}{\hbar c}}-\frac{q}{c}Ae^{-\frac{iq \lambda}{\hbar c}}\psi+\frac{q}{c}\nabla \lambda e^{-\frac{iq \lambda}{\hbar c}}\psi)=e^{-\frac{iq \lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)\psi$$.
The issue I am having trouble understanding is why this would imply $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)^2\psi'=e^{-\frac{iq \lambda}{\hbar c}}(-i\hbar \nabla -\frac{q}{c}A)^2\psi$$. Wouldn't $$(-i\hbar \nabla -\frac{q}{c}A+\frac{q}{c}\nabla \lambda)$$ also act on $$(-i\hbar \nabla -\frac{q}{c}A)$$?
Wait. Just figured it out. Thank you.
  • · Replies 17 ·
