What is Gauss's Law and How Does it Relate to Electric Fields and Surfaces?
  • Thread starter Thread starter Northbysouth
    Gauss's law Law
Gauss's law relates electric fields to the charge enclosed within a surface, highlighting the concept of flux, which measures how much electric field passes through a surface. It is mathematically represented in both integral and differential forms, linking the surface integral of the electric field to the total charge inside a volume. The law is particularly useful in scenarios with symmetry, allowing for easier calculations of electric fields without complex summations. Understanding Gauss's law can be enhanced by relating it to the fundamental theorem of calculus, which describes the relationship between integration and differentiation. Overall, Gauss's law is a fundamental principle in electromagnetism, forming a key part of Maxwell's equations.
Northbysouth
My professor explained it and class and I've tried reading the book but I just cannot wrap my mind around what Gauss's law is.
I understand that it has to do with electric fields and surfaces; the amount of something passing through a surface.
I think my main problem is that I can't think of a good practical application of Gauss's law. Can anyone help me?
The integral form of Gauss's law is the 3d version of something you already should have a grasp of: the fundamental theorem of calculus.
What is the fundamental theorem of calculus? Here's a refresher:
\int_a^b F'(x) \; dx = F(b) - F(a)
For any differentiable function F(x) whose derivative is F'(x). From this, we get the idea that integration and differentiation naturally cancel one another in a particular way.
Let's think about this theorem another way, though. Key to this theorem is the interval [a,b]. This could be thought of a a segment of a number line--a nice, continuously connected stretch. It has a "directionality" or "orientation" that tells us to go from a to b and not the other way around. It also has a boundary: the point b is the upper boundary and a is the lower boundary. We sum or "integrate" the function F(x) on this boundary--it's just an integral over two points is pretty trivial.
The fundamental theorem is extended to 2d and 3d and above in the following way: on some region V, the integral of a function over the boundary of V is equal to the integral of the derivative over the entirety of V.
Gauss's law is the 3d case for a vector field. The surface integral is the integral of the function over the boundary. The volume integral is the integral of the derivative over the whole of the volume.
To help people think about this in an "intuitive" way, we have the concept of flux--where the electric field is perpendicular to the surface, there is more flux passing through the surface, similar to fluid passing through a net or light through a window. And we say that flux related to the charge enclosed--the charge being the volume integral of charge density, which is itself the derivative of the electric field.
The integral form of Gauss's law allows us, through symmetries of the problem, to find the electric field from a charge distribution without going through a brute-force calculation of summing over a bunch of differential elements and treating them all like point charges.
What Murphrid describes is usually known as "Gauß's Theorem" and refers to a mathematical theorem in vector calculus in threedimensional euclidean space. It says
\int_{V} \mathrm{d}^3 \vec{x} \vec{\nabla} \cdot \vec{A}(\vec{x})=\int_{\partial V} \mathrm{d}^2 \vec{F} \cdot \vec{A}(\vec{x}).
Here \vec{A} is a sufficiently well-behaved vector field, V a volume with sufficiently "nice" shape and boundary in threedimensional Euclidean space, and \partial V its boundary. The orientation of the surface-normal vectors \mathrm{d}^2 \vec{F} is such that they point out of the volume V.
Gauß's Law is one fundamental equation in electromagnetism and thus part of Maxwell's equations. It says (in Heaviside-Lorentz Units)
\vec{\nabla} \cdot \vec{E}=\rho.
Here \vec{E} are the electric components of the electromagnetic field (mostly just called "the electric field") and \rho the density of electric charges.
Using Gauß's theorem, you get the integral form of the same law,
\int_{\partial_V} \mathrm{d}^2 \vec{F} \cdot \vec{E} = \int_V \mathrm{d}^3 \vec{x} \rho(\vec{x})=Q_{V}.
Again the orientation of the surface vectors is as explained above. It tells you that the electric flux, i.e., the surface integral over the electric field on the left-hand side of the equation always equals the total charge contained in the volume, bounded by the surface.
Sometimes, if a problem is sufficiently symmetric, you can use the integral form to determine the electric field. The most simple case is the field of a point charge Q, which we put for simplicity in the origin of the coordinate system. Due to spherical symmetry, we expect that the electric field is radial and its magnitude only depends on the distance from the charge, i.e., we make the ansatz
\vec{E}=E(r) \vec{e}_r,
where \vec{e}_r=\vec{x}/|\vec{x}| is the radial unit vector.
Now take a sphere S_R of radius R around the origin and use spherical coordinates for the surface integral. The surface normal vectors in standard spherical coordinates (r,\vartheta,\varphi) are
\mathrm{d}^2 \vec{F}=\mathrm{d} \vartheta \; \mathrm{d}\varphi \; \sin \vartheta \vec{e}_r.
From this you get for Gauß's Law
4 \pi R^2 E_r(R)=Q
and thus immediately the Coulomb-field solution
E_r(R)=\frac{Q}{4 \pi R^2}.
It is pretty easy to show that indeed
\vec{\nabla} \cdot \vec{E}=0 \quad \text{for} \quad \vec{x} \neq 0.
That the factor is correct, we have just proven with the integral form of Gauß's Law. At this step you necessarily need the integral form, because a point charge is a singularity, because the corresponding charge density is given by a Dirac \delta distribution,
\rho(\vec{x})=Q \delta^{(3)}(\vec{x}).
Basically the flux of electric field coming out of a surface has to match the amount of electric charge confined within this surface. This applies to any surface.
A problem in gauss law is that you should have a certain symmetry situation so that the direction of electric field can be guessed otherwise you will have to solve the corresponding poisson eqn for the given charge distribution and then take derivatives of potential so obtained to get the electric field.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
