General Formula For Reflection Direction
A particle's reflection direction upon colliding with a wall varies based on the wall's orientation, with different formulas for horizontal and vertical tangents. For horizontal surfaces, the reflection direction is calculated as 180 minus the incidence angle, while for vertical surfaces, it is 360 minus the incidence angle. A general formula that applies to both scenarios has been proposed: C = 2B - A, where A is the incidence angle and B is the angle normal to the wall. This formula effectively accounts for the 90-degree difference between normal and tangent angles. The discussion concludes with gratitude for clarifying the general formula needed.
VeryBadAtMath
An Example Scenario:
A particle moves at 32° and collides with a wall. This wall is rectangular in nature, which means that there is both horizontal and vertical sides.
On a horizontal tangent, it would work like this (sorry for ugly, not-to-scale diagrams):
[PLAIN]http://img198.imageshack.us/img198/7808/questionsc.jpg
(reflects at 148°)
However, on a vertical tangent it would reflect like this:
[PLAIN]http://img808.imageshack.us/img808/2064/question2.png
(reflects at 328°)
This means that:
  • On horizontal tangent: reflectionDirection = 180-incidenceDirection
  • On vertical tangent: reflectionDirection = 360-incidenceDirection
It's lame to have two different formulas, so is there a general formula for the reflectionDirection that works with both vertical and horizontal tangents? It's fine if it uses radians instead of degrees.
Mathematics news on Phys.org
If the incoming angle is A, and B is an angle normal to the wall, then the reflected angle C is given by C = B - A.
Thanks, but that was not what I was looking for.
In case someone else needs to know, the general formula is:
C = 180+2B-A
Where A is the direction of incidence, B is the direction of tangent (0 if horizontal, 90 if vertical) and C is the direction of reflection.
Well the normal and tangent angles are 90 degrees different, so it all works.
Also, I meant C = 2B - A in my last post, sorry.
Thanks a lot for this conversation. I was searching for this...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
