Proving Constant Angular Velocity and Acceleration in Circular Motion
In summary: No, you knew from the original position vector that the mass was moving in a circle with radius 2: if x=2 cos(\omega t)and y= 2 sin(\omega t), then x
jiboom
91
a particle moves in the xy plane such that at a time t it is at a point (x,y) where
x=2cos(at)
y=2sin(at)
prove particle moves in a circular path with constant angular velocity. prove that the acceleration of the particle at time t is in the direction of the radius from the particle to the centre of its path.
so i have
R=[2cos(at),2sin(at)]
V=[-2asin(at),2acos(at)]
A=[-2a^2cos(at),-2a^2sin(at)]
not sure how to show angular is constant.
i can take |V| and that s constant but I am not using angular velocity.
for the second part:
if if i take direction of A= (d2y/dt2)/(d2x/dt2)=tan(at) where d2y/dt2 is second derivative of y wrt t
does this answer the question as motion is circle centre (o,0) so any radius will have tan (at) as its gradient?
hi jiboom! :smile:
(try using the X2 button just above the Reply box :wink:)
that's fine :smile: … now use v = rω (and r is constant) :wink:
erm :redface:
isn't it obvious that A is parallel to (x,y)? :wink:
now you point it out, yes it is:)
i was going to use v = rω but as i am taking |v| am i not just getting angular speed not velocity?
think I am being thick.
is it that as angular velocity only depends on the angle we have |ω|=ω
just as v=|v| for 1-d motion
sorry but I am now confused again.
the question actually says
x=2cosωt
y=2sin ωt
so
V=V=[-2ωsin(ωt),2ωcos(ωt)]
so |V|=2ω
so using v=rω only gives me r=2?
x=2cosωt
y=2sin ωt
so
so |V|=2ωso using v=rω only gives me r=2?
No, you knew from the original position vector that the mass was moving in a circle with radius 2: if [itex]x=2 cos(\omega t)[/itex]and [itex]y= 2 sin(\omega t)[/itex], then [itex]x^2+ y^2= 4 cos^2(\omega t)+ 4 sin^2(\omega t)= 4[/itex].
The calculation you have done is the derivation of [itex]v= r\omega[/itex]!
so what do i need to say to justify angualr velocity is constant?
hi jiboom! :smile:
(been out for the evening o:))
yup, x=2cosωt y=2sin ωt means r = 2 and angular speed = ω !
again, it's obvious!
go to sleep on it :zzz:, and it'll all be obvious in the morning!
tiny-tim said:
hi jiboom! :smile:
lol. won't be sleeping til i get this.
i don't have much here to play with.
v=rω
now is ω angular velocity or angular speed?
the v i have is not angular velocity and not constant
r is 2
now in your first post you said to use v=rω but then i just get r=2 so that does not show
angular velocity = constant
think its going to be long night unless i get a big nudge here,its not obvious to me due to a lack of understanding about velocity v speed |v| angular velocity ω and angular speed | ω|
jiboom said:
v=rω
what's the difference??
we're in 2D, so they're the same
r is 2
but you know that v is constant (from the formula), so it does :smile:
… its not obvious to me due to a lack of understanding about velocity v speed |v| angular velocity ω and angular speed | ω|
i think you're over-thinking this
v is velocity, v is speed, v = |v|
ω is angular velocity, ω is angular speed, ω = |ω|
v = rω
v = ω x r :wink:
i see what you are saying but I am thinking along these lines:
ω
then how can i then say |v| is constant? |v| is 2ω so is only constant if ω is but that is what I am trying to show
and i don't understand
v = ω x r
lhs is a vector,but rhs is vector product of 2 scalars ?
tiny-tim has gone off-line. can you help explain what they were getting at?
hi jiboom! :smile:
(just got up :zzz:)
jiboom said:
ω
v = |v| is constant because the coordinate formula for v shows it is
v = ω x r
no, ω and r are both vectors, the rhs is a vector product of two vectors
(technically, ω is a pseudovector :wink:)
v = ω x r is the definition of the angular velocity vector for a rigid body
tiny-tim said:
hi jiboom! :smile:
(just got up :zzz:)
im afraid I am totally lost here.
v = |v| is equal to 2ω so how are you saying this is constant?
im trying to show ω is constant which you seem to be saying,forgive me if I am misunderstanding, is equal to ω
so i don't see how the constancy of v follows without assuming what I am trying to show, ie ω is constant.
v = ω x r: still don't see what the vector is for ω. i thought the r was radius,but i now think its the postion vector of the particle.
hi jiboom! :smile:
jiboom said:
… so i don't see how the constancy of v follows without assuming what I am trying to show, ie ω is constant.
it follows from the following coordinate equations …
… what is |v| ? :smile:
ω is the vector of magnitude ω pointing along the axis of rotation
and yes, r is the position vector of the particle
important
v = ω x r is an equation you need to be completely familiar and happy with
you need to study it in your books or wikipedia or other internet site (google "angular velocity" and "rigid body") until you are :wink:
tiny-tim said:
hi jiboom! :smile:
important
as i say |v|=2ω, but if ω is the angular velocity then i can't say this is constant without assuming what i want to prove.
i should say,i have changed that a in my op to ω as that is the letter the question uses.
anyone ?
tiny-tim said:
hi jiboom! :smile:
hi. don't give up on me just yet :)
i do appreciate your help and just need one last shove to get there.
all i need convincing off now is that the omega=angular speed =|v| is constant.
does this follow from the question? if this is so,then for sure i am happy |v|=constant => angular velocity is.
in your original post, you wrote …
so |V| = … ? :smile:
hi,thanks for coming back.
forget the a,the letter used in the question was omega.
i know what |V| is,it is just 2omega
but...
if this omega (a in my original post) is the angular speed i can't say |v| is constant UNLESS i know omega in the question is constant?
maybe i should be clearer, when in question i have
R=(2cos wt,2sinwt)
as this w is not said to be constant in the question i could have w=w(t) and should really have
V=(-2sin(wt)(d(wt)/dt),2cos(wt)(d(wt)/dt)
maybe an easier question would be to clear up what the w is in the question
so from
R=(2coswt,2sinwt)
is the w the same as |w| the angular speed?
if so,is it just to be assumed its a number and not a function of some variable such as time as it's not writtem w(t)?
R=(2cos wt,2sinwt)
oh i see! :tongue2:
no, i think it's safe to assume that the ω in the question is constant (in exactly the same way as you would if it was a instead of ω :smile:) …
it never occurred to me to think otherwise!​
stop imagining that the questions are more difficult than they really are! :rolleyes:
yes! :smile:
tiny-tim said:
oh i see! :tongue2:
yes! :smile:
great,thanks for your time with this.
What is general motion of a particle?
The general motion of a particle refers to the movement of a single point or object in space over time. This can include linear motion, circular motion, and combinations of both.
What factors affect the general motion of a particle?
The general motion of a particle is affected by several factors, including the initial velocity, acceleration, external forces, and the mass of the particle. The direction and magnitude of these factors determine the path and speed of the particle.
How is the general motion of a particle represented mathematically?
The general motion of a particle can be represented mathematically using equations such as the position-time equation, velocity-time equation, and acceleration-time equation. These equations relate the position, velocity, and acceleration of the particle at any given time.
What is the difference between uniform and non-uniform motion of a particle?
Uniform motion of a particle is when its speed and direction remain constant over time, while non-uniform motion is when there are changes in speed or direction. In uniform motion, the velocity-time graph is a straight line, while in non-uniform motion, the graph is curved.
How is the general motion of a particle used in real-world applications?
The study of general motion of a particle is used in various fields such as physics, engineering, and robotics, to understand and predict the behavior of objects in motion. It is also used in practical applications such as designing roller coasters, predicting the trajectory of projectiles, and developing control systems for vehicles and machines.
