General rule regarding solving each differnetial
  • Thread starter Thread starter hangainlover
    General
hangainlover
(3y^2 + 2y)y' = xcosx
xyy'=ln(x) ; y(1)=2
for the first one i get y^3 + y^2= (x^2) sin(x) +cos(x) + C (constant)
and the second one is y^2 + ln(x)^2 +4
the problem is there is no way i can define those two as function y of x or function x of y
because of the exponents.
So my question is, if a question is asking for a solution to a differential equation, can we just leave it as that above?
xyy'=ln(x) ; y(1)=2
The left side is correct, but you made a mistake when you integrated xcos(x). You can check what you have by differentiating x2sin x + cos x. If your integration is correct, you should get d/dx(x2sin x + cos x) = xcosx.
Once you fix your error, you're done. It's not always possible to get the solution so that you have y as a function of x. In this case you will have y as an implicit function of x.
You might have made a typo here. The solution should be y2 = (ln x)2 + 4. It's probably OK to leave it this way, but if you need to, you can solve for y, as y(x) = +/-sqrt( (ln x)2 + 4)
yeah i made a typo in both solutions. I am sorry. I was really rushed to type it in
the first one should be y^3+y^2 = xsin(x) +cos(x) + C and the second one is y^2 = (ln x)^2 + 4 not y^2=ln(x)^2 +4
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
