General solution of Schrodinger eq. proof
dingo_d
Let |\psi\rangle and |\psi '\rangle be solutions to the same Schrodinger equation. Show than, that c|\psi\rangle+c'|\psi '\rangle is the solution, where c and c' are arbitrary complex coefficients, for which holds: |c|^2+|c'|^2=1
Now this follows from linearity of the Schrodinger equation (that every linear combination is the solution). But how to prove it directly?
I've started with:
i\hbar \frac{\partial}{\partial t}|\psi\rangle=\hat{H}|\psi\rangle
i\hbar \frac{\partial}{\partial t}|\psi'\rangle=\hat{H}|\psi'\rangle
And added them up:
i\hbar\left( \frac{\partial}{\partial t}|\psi\rangle+\frac{\partial}{\partial t}|\psi'\rangle\right)=\hat{H}(|\psi\rangle+|\psi'\rangle)
And... now I don't know what to do next :\
I think I'm taking the superposition principle way to lightly :\
Call |\psi''\rangle=c|\psi\rangle+c'|\psi'\rangle
Show that |\psi''\rangle solves the Schrodinger equation. You will se that conditions on c and c' are irrelevant for this question.
Ok... but how? :\
Calculate
<br /> i\hbar \frac{\partial}{\partial t}|\psi&#039;&#039;\rangle<br />
remembering that c and c' are constants, and see if it the same as \hat{H}|\psi&#039;&#039;\rangle
Ok so,
<br /> i\hbar \frac{\partial}{\partial t}|\psi &#039;&#039;\rangle=\hat{H}|\psi &#039;&#039;\rangle<br />
<br /> i\hbar \frac{\partial}{\partial t}|\psi &#039;&#039;\rangle=i\hbar\frac{\partial}{\partial t}\left(c|\psi\rangle+c&#039;|\psi&#039;\rangle\right)=c\underbrace{i\hbar\frac{\partial}{\partial t}|\psi\rangle}+c&#039;\underbrace{i\hbar\frac{\partial}{\partial t}|\psi&#039;\rangle}=c\hat{H}|\psi\rangle+c&#039;\hat{H}|\psi&#039;\rangle=\hat{H}(c|\psi\rangle+c&#039;|\psi&#039;\rangle)=\hat{H}|\psi&#039;&#039;\rangle<br />
And that's it?
And that's it!
W00t! Thanks a lot :D
