What if we redefine force in physics as a function of velocity and momentum?
  • Thread starter Thread starter MathematicalPhysicist
    Force
Redefining force in physics as a function of velocity and momentum, expressed as F=F(p,q,dp/dt,dq/dt), raises questions about its implications on existing equations. While some argue this approach could lead to different mathematical forms, the underlying physics would remain unchanged, as momentum and velocity are interdependent. A proposed formulation involving a quantity Q that minimizes action could yield equivalent equations of motion to classical mechanics. However, defining force in terms of its own derivative may lead to inconsistencies and confusion. Clarification from the original poster is needed to further explore the concept's validity and utility.
What if we wouldn't define a force as F=dp/dt but instead as a function of
F=F(p,q,\dot{p},\dot{q})
How will this change the equations of physics?
Maybe there are cases where the force behaves as k\cdot \frac{dp}{dq} where 'k' is some constant to fix the dimensions.I am just tinkering with this idea, really.
Please define your terms - i.e. can you express the second equation in words?
It looks far too general for any sensible answer.
In general - it would not change the physics ... the equations would look different, they'd have different letters in them, but would be mathematcally identical.
If you wanted to use some function of p and dp/dt for force, and you wanted to use that to get an equation of motion, then you will find yourself only needing the dp/dt part.
You realize that you can define any word to mean anything you like? All you are doing is assigning the label to a different object.
That's sort of a strange generalization, because "momentum" really only has a meaning relative to the equations of motion. Typically, momentum is computed from the velocity (or vice-versa) so they aren't independent dynamical variables.
However, now that I think about it, there is a formulation of classical mechanics that puts momentum and velocity on equal footing, without assuming one is derivable from the other.
Assume that there is a quantity Q(p,\dot{p},q,\dot{q}) associated with the motion. The equations of motion are derived by the requirement that
\int Q dt is minimized. Then that leads to the equations of motion:
\dfrac{d}{dt} \dfrac{\partial Q}{\partial \dot{q}} = \dfrac{\partial Q}{\partial q}
\dfrac{d}{dt} \dfrac{\partial Q}{\partial \dot{p}} = \dfrac{\partial Q}{\partial p}
If you choose Q carefully, this is equivalent to the usual equations of motion. For example, if you let:
Q = \dfrac{p^2}{2m} + V(q) - p \dot{q}
then the equations of motion become:
\dfrac{d}{dt} (-p) = \dfrac{\partial Q}{\partial q}
0= \dfrac{p}{m} - \dot{q}
Which is equivalent to the usual equations of motion.
I think that if there was such a force, then the definition of "force", i.e. F = \dot{p} woulld be inconsistent, since the magnitude that defines the force (\dot{p}) would be in what we want to define (F) . To me, it looks non-sence to define "something" using terms that invlolve that "something".
I still think it's like asking what our calculations would be like if we defined quadratics as third order polynomials and lines as second order. It would be a funny thing to do - but there's nothing stopping anyone. Math would be just the same, only we'd say that ballistic motion in the absence of air resistance is "linear" (it would just mean something different to what we are used to.)
That's why it doesn't matter that the Newtonian definition of force is inconsistent with the above definition... it's a different definition. Some definitions are just more useful than others - with one of the considerations being communication.
I think we need OP to clarify what was meant.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
