Generating a rippled voltage supply
  • Thread starter Thread starter taleebe
    Supply Voltage
The discussion focuses on generating a rippled voltage supply using a BJT power follower in SPICE simulation. The user seeks guidance on modeling the circuit with a sinusoidal input of 200mV amplitude and a frequency range up to 20 MHz, aiming for a flat output voltage around 3.3V while handling a load that sinks up to 1A. A suggestion is made to DC couple the output by removing a capacitor, which would allow both AC and DC components at the output. The user is currently experimenting with different NPN BJTs for the simulation. Overall, the conversation emphasizes the importance of circuit configuration and component selection in achieving the desired output characteristics.
Sure. You want to model a BJT power follower in SPICE? Can you post a copy of your SPICE deck?
im thinking of a schematic like this with vin as a varying sinusoidal input(0-20 Mhz) of amplitude 200mv. I want vout to be reasonably flat across this range.Also at my output id like to have a DC of around 3.3V. It is also worth noting that my load sinks up to 1A of current.Is it worth a shot?
That's a good start for a circuit to simulate, but I'd DC couple the output (delete C3). Which NPN BJTs were you thinking of simulating?
i see...deleting C3 would let me have AC and DC at the output!
as for the type of NPN to use I am not really sure,right now its trial and error
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
