Generation of Static Electricity
Calculating the generation of static electricity between two materials involves understanding their interaction at a molecular level. Key factors include the velocity, volume, and surface area of the moving material, as well as the electron affinities of both materials. The complexity of this problem is akin to determining the coefficient of friction from first principles. Accurate calculations would require detailed knowledge of surface interactions and charge transfer mechanisms. Overall, while theoretical calculations are possible, practical application may present significant challenges.
eqm
I was wondering if and/or how one would could calculate the the generation of static electricity between 2 materials.
For example material A is immersed in substance B and moves within it at a constant velocity. Knowing the velocity and volume / surface area of material A and the electron affinities of both material A and substance B, could you calculate the rate at which material A loses / gains electrons?
I suspect you would need to know how the two surfaces interact at the molecular level. That would make it a difficult problem. Perhaps similar to trying to calculate the coefficient of friction from first principles.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
