A Geodesic Motion
Summary
Would a body in free fall 'feel' a force acting upon it if the curvature of spacetime was suddenly increased?
My current understanding is that a person falling toward the surface of a planet with no atmosphere, would feel no force acting upon themselves even though they are accelerating relative to the planet. If the mass of the planet suddenly tripled while the person is in free fall, would the person 'feel' anything as a result or would they still feel no apparent force even though their rate of acceleration increases?
Thanks,
James
Orodruin
Staff Emeritus
Insights Author
2018 Award
15,598
5,622
A point person in free fall will not feel any force. An extended person will be subject to tidal forces due to geodesic deviation.
It cannot do that. That would violate local energy-momentum conservation.
Ibix
Insights Author
4,981
3,288
How would the mass of the planet triple suddenly? Bear in mind that the Einstein field equations require that you respect local conservation of energy, so "the mass just appears out of nowhere" doesn't give a consistent scenario.
Assuming something like "a planet slams into it from the other side at near enough the speed of light that its gravitational influence wasn't felt earlier" then you'd get a gravitational wave passing through you and then you'd be in the region of higher curvature (and then dead from the debris of such a cataclysm shortly thereafter). You might (in principle, at least) feel the gravitational wave as it passes through you because this is tidal gravity. The geodesic motion of the different parts of your body would be in different directions, which I imagine might well feel like being pulled apart. However, the only actual forces in play are the internal structural forces of your body trying to keep itself together.
A.T.
1,423
The curvature is increasing all the time as you fall towards as massive body. It increases the tidal forces, leading to deformations which you could feel in extreme cases.
...would the person 'feel' anything as a result or would they still feel no apparent force...
To term "apparent force" usually refers to effects that you cannot "feel", and are due to the chosen coordinate system.
Thanks for the replies and explanations.
Want to reply to this thread?
"Geodesic Motion" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
