Calculating Relative Humidity at 60°F
At 60°F, the maximum water vapor capacity is 5.8g/cubic foot. Given that the actual water vapor content is 4.8g/cubic foot, the new relative humidity can be calculated using the formula: (actual vapor content / max capacity) x 100. This results in a relative humidity of approximately 82.76%. Understanding the initial 60% relative humidity at 70°F helps in making the calculations easier. The discussion emphasizes the importance of knowing both temperature and water vapor capacity for accurate humidity calculations.
jxs919
My brain is fried on other subjects. Help me!
Given: Max Water Vapor Capacity for Air @ 70 degrees F (21 deg. C)= 8g/cubic foot.
At 60% relative humidity, the actual water vapor content is 4.8g/cubic foot.
If the room temperature were lowered to 60 degrees F (16 deg. C) at which the max water vapor capacity is 5.8g/cubic foot, calculate the new relative humidity.
help me get started here...
I would start by looking at where 60% (0.60) comes from -- then it will be easy to calculate from there.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
