Geometric Series Homework: Converge or Diverge? Find Sum
The discussion revolves around the convergence of the series from n=1 to infinity of (2)/(n^2-1) and the attempt to find its sum. Participants are exploring the nature of the series and whether it can be expressed as a geometric series or through partial fractions.
  • One participant suggests using a limit comparison test to determine convergence, while another proposes rewriting the series in partial fractions to check for telescoping behavior. There are also questions regarding the starting index of the series and its implications on convergence.
Some participants are actively engaging with the problem, offering suggestions for approaches such as partial fractions and checking limits. There is a recognition of potential confusion regarding the series' starting point, which may affect the convergence analysis.
There is a mention of a potential issue with the series starting at n=1 due to an undefined term, which raises questions about the correct formulation of the series and its convergence properties.
Rossinole
Does the series from n=1 to infinity of (2)/(n^2-1) converge or diverge? If it converges, find the sum.
I can see right away that the series converges by a limit comparison test by looking at the series. However, to find the sum I have re-write that as a geometric series. There is nothing, at least to me, that gives away how to re-write that as a geometric series. That's where I'm stuck.
Thanks for any help.
Why don'y you write [itex]\frac{2}{n^2-1}[/itex] in partial fractions and see if it is a telescoping series?
Find
[tex]\sum_{n=1} ^{N} \frac{2}{n^2-1}[/tex]
and then check what happens as [itex]N \rightarrow \infty[/itex]
I see it now. Thank you.
what's the summation of the series?
1.A^1 + 2.A^2 + 3.A^3 + ....+n.A^n.
please reply
please reply
What have you tried so far on it?
please reply
Is this related to the original post or something separate?
Are you sure you don't mean
[tex] \sum_{n=2}^\infty \frac{2}{n^2-1}[/tex]
i.e.- the sum starting at [tex]n = 2[/tex]? If you try to start at [tex]n = 1[/tex] the very first term is undefined (can't divide by zero) so the series would not converge. As I mentioned - this makes the difference between the series converging and not converging, and will influence your value for the sum.
Yes, he probably meant the sum to start at n=2.
Jainal36- you should really start new threads rather than hijacking others, but ill help anyway - that's just A times the derivative of a series you know how to sum.
