Gibbs free energy from partial pressures
The discussion centers on calculating the Gibbs free energy (ΔG) for the reaction CH3OH(g) <-> CO(g) + 2H2(g) at 298 K using given partial pressures. The initial calculation of the equilibrium constant (K) was found to be incorrect, leading to an erroneous ΔG value of -13.1 kJ. Participants noted the importance of unit consistency and the correct application of the gas constant R, suggesting it should be converted to kJ. It was also highlighted that if K is less than 1, ΔG should be positive, indicating a misunderstanding in the sign of the result. The conversation emphasizes the need for careful attention to detail in calculations involving thermodynamic equations.
kmwolf92
Consider the following reaction:
CH3OH(g) <-> CO(g)+2H2(g)
Calculate ΔG for this reaction at 298 K under the following conditions:
PCH3OH=0.895atm
PCO=0.115atm
PH2=0.200atm
ΔG=-R*T*ln(K)
where R is the gas constant 8.314 J/molK, T is 298 in this case, and K is determined from the partial pressures.
I calculated K by (0.2002)(0.115)/0.895 and found it to be 0.00514.
This produced deltaG=-8.314*298*ln(0.00514)=-13.1 kJ, but this is incorrect according to the website. I'm really not sure what is going wrong; this is my last attempt on any of the pressure problems on this homework, so I'd like to get this figured out. My guess right now is that it's related to the # of moles not being used (as R suggests), but I'd appreciate input before I use my last attempt, especially so it's drilled into my brain after this assignment.
Thanks for any help!
The consistency in units is often the case
Since the problem doesn't give Delta G naught, we calculate Delta G reaction assuming the reaction is at equilibrium (ΔG = 0)
ΔG° reaction (kJ) = - R (J/°K.mol) x T(°K) x ln (Pp/Pr)​
In this case, convert R = 8.314x10-3 (kJ/°K.mol)
Likes Greg Bernhardt
You neglected the minus sign. (Clue: if K < 1, ΔG0 must be positive.) Is +13.1 kJ/mol correct, according to your website?
The use of °K instead of K was discouraged in 1967.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
