Give all the polar coordinates corresponding the rectangular point
8 replies · 3K views
shamieh
Give all the polar coordinates corresponding the rectangular point $$(-1, \sqrt{3})$$
Am i setting this up right?
so would I use $$(r, \theta)$$
so $$x = rcos(\theta)$$
$$y = rsin(\theta)$$
$$r^2 = x^2 + y^2$$
so:
$$(-1)^2 = (-1*\frac{2\pi}{3})^2 + (-1*\frac{11\pi}{6})$$ ?
$$r^2 = x^2 + y^2$$
Yes, that is correct.
so:
But I have no idea what is meant by this. But that equation certainly isn't true. [tex]\left(-\frac{2\pi}{3}\right)^2= \frac{4\pi}{9}[/tex] and [tex]\left(\frac{-11\pi}{6}\right)^2= \frac{121\pi^2}{36}[/tex]. Those do NOT add to 1.
You are given that x= -1 and [tex]y= \sqrt{3}[/tex] so that [tex]r^2= (-1)^2+ (\sqrt{3})^2= 1+ 3= 4[/tex]
By dividing [math]y= r sin(\theta)[/tex] by [tex]x= r cos(\theta)[/tex] you get
[tex]tan(\theta)= \frac{y}{x}= \sqrt{3}{-1}= -\sqrt{3}[/tex].
How about:
$$r^2 = (-1)^2 + (\sqrt{3})^2$$
$$r^2 = 4$$
$$r = 2 $$ or $$ - 2$$... I understand all of this...
But then..What is going on here?
How are we obtaining the points $$(2, \frac{2\pi}{3} +(-) 2n\pi)$$
HOW does he know that we have the angle of 2pi/3 from the work above alone?
- - - Updated - - -
Also, would that mean that my answer is just $-\sqrt{3}$ as the final answer??
Look at two things: in which quadrant is $\theta$, and as HallsofIvy mentioned:
$$\tan(\theta)=\frac{y}{x}$$
So what must you conclude regarding $\theta$?
I got
$$cos\theta = x/r = -1/2$$
$$sin\theta = y/r = \sqrt{3}/2$$
thus $$\theta = 2\pi/3$$ in Quadrant II
So would my points be $$(2,2\pi/3)$$ ?
Hello, shamieh!
Give all the polar coordinates corresponding to
the rectangular point [tex](\text{-}1,\,\sqrt{3})[/tex]
We are given: .[tex]\begin{Bmatrix}x &=& \text{-}1 \\ y &=& \sqrt{3} \end{Bmatrix}[/tex]
We want: .[tex]\begin{Bmatrix}r, & \text{where }r^2 \,=\,x^2+y^2 \\ \theta, & \text{ where }\tan\theta \,=\,\frac{y}{x}\quad \end{Bmatrix}[/tex][tex]r^2 \:=\:x^2+y^2 \;=\;(\text{-}1)^2 + (\sqrt{3})^2 \:=\:1+3 \:=\:4[/tex]
. . Hence: .[tex]r \,=\,\pm2[/tex][tex]\tan\theta \,=\,\frac{\sqrt{3}}{\text{-}1} \,=\,\text{-}\sqrt{3}[/tex]
. . Hence: .[tex]\theta \:=\: \frac{2\pi}{3} + \pi n[/tex]
Therefore: .[tex](\text{-}1,\,\sqrt{3}) \;=\;\begin{Bmatrix}\left(2,\;\tfrac{2\pi}{3}\!+\! 2\pi n\right) \\ \left(\text{-}2,\;\tfrac{5\pi}{3}\!+\!2\pi n\right) \end{Bmatrix}[/tex]
soroban said:
Hello, shamieh!
That makes complete sense! But can you explain to me why the answer says:
$$(2, 2\pi/3 $$ +/- $$ 2n\pi)$$ and $$(2, -\pi/3$$ +/- $$ 2n\pi)$$ ?
soroban said:
Hello, shamieh!
So you are just taking $$0 + \frac{2\pi}{3}$$ to get : $$(2, \frac{2\pi}{3} + 2\pi n)$$
and then you are taking $$2\pi - \frac{2\pi}{3}$$ to get: $$(-2, \frac{5\pi}{3} + 2\pi n)$$Also can you explain how my teacher got for his solution, $$(2, \frac{2\pi}{3} \pm 2\pi n)$$ and $$(2, -\frac{\pi}{3} \pm 2\pi n)$$
Also this may sound like a dumb question but how come we obtained just + in our final solution where as my teacher has $$\pm$$ in his solution...
Although Soroban wrote "-2" for r, in polar coordinates, "r" is usually taken to be positive. Of course, that just reverses the direction which is the same as adding [tex]\pi[/tex] to the angle. That is [tex](-2, 5\pi/3)[/tex], which, technically, means "go to the direction that make angle [tex]5\pi/3[/tex] with the positive x-axis, then go in the opposite direction" is the same as [tex](2, 5\pi/3- \pi)= (2, 2\pi/3)[/tex].
As for the difference between Soroban's "+" and your teacher's "[tex]\pm[/tex]", Soroban is allowing n to be any integer, positive or negative while your teacher is, apparently, only allowing n to be non-negative.
