Given f(x) = x^3 + 4x -5, show x-1 is a factor
  • Thread starter Thread starter DeanBH
The polynomial f(x) = x^3 + 4x - 5 has x - 1 as a factor, confirmed by f(1) = 0. It can be expressed as (x - 1)(x^2 + x + 5). The discussion then shifts to finding the real root of the equation f(x) = 0, noting that the discriminant b^2 - 4ac is negative, indicating one real root and two complex roots. The real root is identified as 1, derived from the factorization. The conversation highlights confusion over the quadratic formula and the reasoning behind these mathematical concepts.
DeanBH
The polynomial f(x) is given by f(x) = x^3 + 4x -5
show x-1 is factor :
f(1)=0
1+4-5=0 Thus it's a factor.
express in form (x-1)(x^2+px+q)
ends up being X^2 + X + 5.
next question is :
hence show the equation f(x) = 0 has one real root state it's value.
i know i have to use b^2 -4ac. If i do that it's -19 which is <0 so it's 1 value. But how do I find the value. And why does all this stuff work.
My teacher is one that just tells you how to do it. I have no idea why I'm doing it and it makes no sense so it's harder to remember. I would get 1or 2 marks out of 3 for this.
Firstly i don't know how to find out what the real number is. and i don't know why this works.
explain plez?! 8D
? Didn't you start off by showing that f(1)= 0??
And you are trying x so that f(x)= 0??
First a short lesson in discriminants, since you asked why you use them.
Remember the equation for the roots of any polynomial f \left(x \right) = a x^{2} + bx + c is
x = \frac{-b + \sqrt{b^{2} - 4 a c}}{2a} and x = \frac{-b - \sqrt{b^{2} - 4 a c}}{2a}
The term b^{2} - 4 a c is called the "discriminant". If the discriminant is negative, then in you would be taking the square root of a negative number, which you cannot do with the real numbers.
Now, how many roots must f \left(x \right) = x^{3} + 4 x - 5 have?
Do you know the value of any of the roots already?
DeanBH said:
Firstly i don't know how to find out what the real number is …
Hi DeanBH! :smile:
I think you're getting confused … the real number is 1, from the (x - 1) factor that you've already found.
When the question says "show the equation f(x) = 0 has one real root", it means exactly one real root (and two complex roots), instead of three real roots. That's all! :smile:
by working backwards, you can just show that x^3+4x-5 factors into (x^2+5)(x-1)
not sure if your teacher wants you to use the quadratic formula or not, but working backwards works just fine in some cases.
No, it doesn't.
(x2+ 5(x-1)= x3- x2+ 5x- 5, NOT x3+ 4x- 5. Did you mean (x2+ x+ 5)(x- 1)?
i don't think it's is a difficult question ? .
I believe that's already been pointed out several times!
HallsofIvy said:
No, it doesn't.
gah my bad, yes i ment (x2+ x+ 5)(x- 1)
