Given force, need to determine what bearing to use for a crane
The discussion revolves around determining the appropriate bearings for a manual crane capable of lifting a maximum weight of 1000 kg and pulling a winch cable at a specified rate. Participants explore the forces involved, including radial and axial loads, and the calculations necessary to ensure the crane's structural integrity and functionality.
  • One participant estimates the radial force P to be 10 kN based on the weight and winch specifications, but seeks validation for this assumption.
  • Another participant suggests that the base of the lifting arms should be a thick wall steel tube and discusses the side thrust forces involved.
  • There is a discussion about determining reaction forces A_H and A_V, with references to Newton's Second Law and the relationship between linear and angular velocities.
  • Participants express uncertainty about how to determine the radius for the pulley and its impact on the forces involved.
  • One participant questions the presence of axial loads and discusses the potential for axial forces in the context of the crane's design.
  • Another participant mentions that the radial force on the bearing could vary based on the tension in the winch wire and the angle of the pulley.
  • There are calculations presented for dynamic load capacity based on assumed lifetimes and bearing ratings, with some participants questioning the validity of these calculations.
  • Discussion includes the need for a clearer diagram of the crane's components to facilitate better understanding and analysis.
Participants express varying levels of agreement on the calculations and assumptions regarding forces, with some proposing different values for axial loads and radial forces. The discussion remains unresolved regarding the exact forces acting on the crane and the appropriate bearing specifications.
Participants note that the calculations depend on various assumptions, including the definitions of forces and the geometry of the crane. There is also mention of the need for more detailed diagrams to clarify the mechanical setup.
Individuals interested in mechanical engineering, crane design, or bearing selection may find this discussion relevant, particularly those looking to understand the forces involved in lifting mechanisms.
  • #61
erobz said:
Explain how its in static equilibrium with an unbalanced horizontal force component from the support and the tension on the pulley?
The beams are in static equilibrium since they are in rest state but yeah i guess with the pulleys its not in equilibrium once it starts to lift, when we stop the winch then its in static equilibrium.
  • #62
What do you mean by an "unbalanced horizontal force"? Why cant you just assume the forces is right i dont really get this.
  • #63
The forces in the horizontal direction are unbalanced. The beam is not in static equilibrium with the loading your supervisors told you was correct.
?? Do you wan't to find the actual loading on your mounting bracket?
  • #64
Im fine with the forces i have and what the studentassistant has told us, no offense by the way. I dont want to say my mates calculations are wrong since he has got a lot of help from the assistants , if i asked for help of an exercise in my book with these information given would you just ignore the information given and find it yourself? (poorly explained but i think you understand what im saying here). Just assume its 30kN directed as i drew it and 20kN on the side like i drew it, its alright. All i wanna understand is how to determine the bolts.
  • #65
Sizing the bolts requires having as close to an accurate loading as reasonably possible. If you don't care about having accurate loads, then why do you care about sizing the bolts accurately?
Imagine for a moment you are an engineer and you are designing a bridge that your family will travel everyday, and many others families will travel... And you say, but I don't care about the loads being accurate, I just care about sizing these bolts that hold the bridge up...SMH.
Maybe I'm wrong. I'll just gracefully bow out and let someone else help you.
  • #66
Hhahaha yeah but im pretty confident he hasnt done any mistakes. Look, i can discuss this with him later on but i came here to get help from the problems i got, and that is to determine the bolts. If you re-did the calculations and got something else thats fine, but im only for understanding how to get the bolts. I dont get why you are so passionate about re-doing it, there's plenty of cranes with those exact loads he got, why cant you just help me understand how to get dimension the bolts, not even the loading but the general steps as in the formulas like Baluncore showed, i didnt give him numbers but he showed one way of determing the bolts. Let the force thats in compression be called K, no number, and the other force Q, so i got two loads. What principle/method do i have to use in order to determine the bolts?
We dont have much time, im not going to use an hour to re-do his calculations in order for you to just show the method of determining bolts in a crane situation like this. Just having this conversation has been taking way more than an hour.
  • #67
I have this crane that has to be able to lift a weight of maximum 1000kg. Its a type of a manual winch crane thats going to be able to rotate. I need help with the rotating part, i want to determine the bearings inside this rotating part and im thinking to use 2 bearings in there but im not sure if you can use welding on the edge of the bearings and make it stuck? And how i should determine them.
  • #68
@erobz alright fine, we can re-do it then.
  • #69
The bearing system will need to support both axial and radial loads. Why do you have four different bearing surfaces? Why are the two "bearings" so close together? What experience do you have in objects that weigh a ton? Perhaps you can work with someone locally.
es
  • #70
I backed out at post #40, after the base went from square to round, without rational discussion. I now know this is a poorly organised school exercise, we were dealing with a hidden committee, while communicating through a bottleneck. It is still my opinion that, without clear labelled drawings, discussion is a waste of time.
  • · Replies 23 ·
