Given g and T, find volume & mass of atmosphere
The discussion focuses on calculating the mass and volume of a fictional planet's atmosphere using established parameters like gravity, mean surface temperature, and atmospheric composition. The user has determined a gravitational acceleration of 10.33 m/s² and a molar mass of 0.02914 kg/mol for the atmosphere, which is similar to Earth's but with a different nitrogen-oxygen ratio. They explore using the barometric formula to derive pressure but face challenges due to missing parameters. Calculations suggest an atmospheric density of 1.28 kg/m³ and a pressure of approximately 106.2 kPa, raising questions about the plausibility of these values given the planet's larger size and mass compared to Earth. The user is seeking confirmation on the accuracy of their calculations and whether the assumptions made about atmospheric density are valid.
brainfuel
I'm working on building a world, and I have established the mass and radius of the planet, as well as its distance from its star and mean surface temp.
I have determined g (10.33 m/s^2) at sea level, and wonder if this plus the mean surface temp is enough to get a rough idea of the atmosphere's total mass & volume?
Can I just "assign" "appropriate" values for mean atmospheric density and atm pressure at sea level, or will those be dependent on other factors?
TIA
B
If it helps - I've given the atmosphere a composition with a molar mass of 0.02913351 kg/mol.
I considered the barometric formula to solve this, but I don't have Pb, Tb, or Lb.
I don't know all the math behind this, if the composition of the atmosphere is similar to earth, I'm wondering if you could simply increase the mass by the same proportion as the gravity increased. What do you think?
I've given a composition fairly similar to Earth's - the primary difference is the Nitrogen-Oxygen ratio (instead of 78:21, I made it 69:27, & threw in a couple percent Ne to balance it out). I think I've got it sorted - so I'll dump the math here & see if it seems legit.
molar mass (M) = 0.02914 kg/mol
atmospheric density = 1.28 kg/m^3
depth of atmosphere = 120000 m (compared to 100000 m for 99.99997% of Earth's atmosphere, per Wikipedia)
standard temp (T) = 290.75 K
So for a column of air over one square meter, V = 120000 m^3
120000 m^3 * 1.28 kg/m^3 = 153600 kg of atmosphere per m^2 surface area
153600 kg / 0.02914 kg/mol = 5.271105e6 mol
P = nRT/V = 5.271105e6 mol * 8.314472 Pa m^3 / K mol * 290.75 K / 120000 m^3 = 106187.85 Pa = 106.188 kPa = 1.048 atm
I'm not 100% sure on the density - I've found Earth's atmospheric density at sea level ranging anywhere from 1.2 - 1.29 kg/m^3. The average density of Earth's atmosphere comes out to about 0.099 kg/m^3. It seems like I should probably use that in the equation, but then I come up with a pressure of about 82 kPa, which seems much too low. Not sure if the atmosphere should be significantly thicker than earth's, or if I've got a flaw somewhere else in the process??
The wikipedia article on Atmospheric Models is helpful. However, if you have the density, molecular weight, and temperature (all measured) at sea level, (assuming air is an ideal gas) the equation for the pressure at sea level is \frac{\rho{}TR}{M} where \rho{} is the density, R is the molar gas constant, T is the temperature, and M is the molecular weight. The value I get is about 106.2 kPa. This forumla is just a rearrangement of the ideal gas law.
Since the pressure in the atmosphere decreases with altitude, so does its density. It turns out not to be a good approximation to assume it is of constant density for the first 100 Km and zero thereafter.
IsometricPion said:
The wikipedia article on Atmospheric Models is helpful. However, if you have the density, molecular weight, and temperature (all measured) at sea level, (assuming air is an ideal gas) the equation for the pressure at sea level is \frac{\rho{}TR}{M} where \rho{} is the density, R is the molar gas constant, T is the temperature, and M is the molecular weight. The value I get is about 106.2 kPa. This forumla is just a rearrangement of the ideal gas law.Since the pressure in the atmosphere decreases with altitude, so does its density. It turns out not to be a good approximation to assume it is of constant density for the first 100 Km and zero thereafter.
Okay, that makes sense, and seems to work out to the same result I'd found before. Now I just have to find out if that's a plausible number for the planet in question, which has radius r = 7080 km (1.11 x Earth) and mass m = 7.766 e24 kg (1.3 x Earth). Who knows, I may end up doing all the math over again...
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
