Global max/min (multivariable)
7 replies · 4K views
sandy.bridge
Find the global maximum and global minimum of
[tex]f(x, y)=x^3+y^2[/tex]
in the half disk [tex]x^2+y^2\leq{1}, y\geq{0}[/tex]
This is a rather new topic for me, so I am looking for clarification for problems such as these.
First, I determined the critical points of the function.
[tex]\nabla{f(x, y)=3x^2i+2yj}[/tex] and thus has a critical point at
[tex](x, y)=(0, 0)[/tex]
Next, we will consider along the boundary of the half disk. Since the disk is a half circle, I must include the endpoints x=1, x=-1.
We have,
[tex]x=cost, y=sint, (0, \pi{)}[/tex]
We have,
[tex]f(cost, sint)=cos^3t+sin^2t=g(t)[/tex]
Moreover,
[tex]-3cos^2tsint+2sintcost=0\rightarrow{cost=2/3}[/tex]
[tex]g(cos^{-1}2/3)=0.852[/tex]
Next, checking the boundaries at t=0 and t=π
g(0)=1, g(π)=-1
Therefore, f has a global max at the boundary on the half disk of 1 at (1, 0) and a global min of -1 at (-1, 0).
However, I executed two of the tests for determining if critical points are max/mins for the point (0. 0) however all the tests were inconclusive. What else can be done here?
You checked along the boundary, x2 + y2 = 1, but to be thorough, you should also check along the boundary, y = 0 .
Regarding (0,0): Are the second derivatives of f defined at (0,0) ?
Okay, not entirely sure how to show work for checking along y=0. Moreover, I believe the second derivatives are defined at (0, 0), and if they are not, I don't see why considering it's a cubic and square function.
Hi sandy.bridge! :smile:
In (0,0) you'll find that the Hessian 2nd derivative test is inconclusive.
What else can be done?
Well, since there are no other extrema nearby, simply check a few points around (0,0).
Since it's already likely that it is a saddle point, you can verify this by finding a positive and negative value near (0,0).
As for checking along y=0.
What about [itex]x=t, y=0[/itex]?
In particular you will find that (0,0) is a saddle point.
Hello!
Okay, moving the left of the origin along the x-axis, we have
[tex]f(-.1, 0)=(-.1)^3[/tex]
and ro the right
[tex]f(.1, 0)=0.1^3[/tex]
therefore, this illuminates the fact this is a saddle point.
As for your suggestion of x=t, how can this be done? Is "t" not denoting the angle measurement with respect to the positive x-axis?
Good!
"t" can be anything you want. It's just an arbitrary parameter with an arbitrary range.
You could also use simply (x,0) where x is the parameter running from -1 to +1.
Alright, then the global max occurs when x=1, or t=0(angle). Also, the min occurs when x=-1 (t=pi).
max(x, y)=(1, 0)
min(x ,y)=(-1, 0)
