How Do You Solve for Theta in Goniometric Equations?
  • Thread starter Thread starter The Alchemist
    Relationships
The discussion revolves around solving for θ in the equation \(\frac{I_{\pi}}{I_{\sigma}} = \frac{\sin^2{\theta}}{1 + \cos^2{\theta}}\). An initial solution yields \(\theta = \arcsin{\left(\pm\frac{2 I_{\pi}}{I_{\sigma}+I_{\pi}}\right)}\), while a reference paper suggests \(\theta = \arctan{\left(\pm\frac{2 I_{\pi}}{I_{\sigma}-I_{\pi}}\right)}\). Participants note the importance of including square root signs in both expressions and clarify that to derive the arctan expression, one must find cosine θ and divide sine θ by cosine θ. Ultimately, it is concluded that the reference paper likely contains an error by omitting the square root in its arctan expression. The conversation emphasizes the need for careful attention to detail in mathematical derivations.
The Alchemist
Given the following relation for θ:
solve for θ
\cos^2 x + \sin^2 x = 1
If I solve this I get: \theta = \arcsin{\left(\pm\frac{2 I_{\pi}}{I_{\sigma}+I_{\pi}}\right)}
But the paper where this equation is from says: Consequently θ becomes:
Is there a way to come to the arctan expression? Or is the paper wrong? I'm quite stuck.
solve for θ
Are you missing a square root sign on both your expressions?
Because I'm getting \theta = \arcsin{\left(\pm \sqrt{\frac{2I_{\pi}}{I_{\sigma} + I_{\pi}}}\right)} = \arctan{\left(\pm \sqrt{\frac{2I_{\pi}}{I_{\sigma} - I_{\pi}}}\right)}
To get the arctan expression, find cos θ then divide sin θ by cos θ to get tan θ, then take the arctangent.
You're right I missed the square root in the arcsin, the arctan though doesn't have one!
When I solve for cosine θ \theta = \arccos{ \left( \pm \sqrt{ \frac{I_{\sigma} - I_{\pi}}{I_{\sigma} + I_{\pi}}}\right)}
How can I then come to an arctan expression?
When I solve for cosine θ \theta = \arccos{\left(\pm \sqrt{\frac{I_{\sigma} - I_{\pi}}{I_{\sigma} + I_{\pi}}\right)}
Just divide the sine by the cosine. The denominators cancel out.
There should be a sqrt on the arctan expression as well.
Oh, I was too dazzled! thanks for the help.
So the equation in the paper misses the sqrt...
Mistakes in print are nothing new.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
