Good old question about buoyancy and riser in oil industry
When a steel riser is lowered into drilling mud, its surface weight is affected by buoyancy, equating to the weight of the steel in the mud. Upon latching the riser to an existing pipe, the weight at the surface shifts to the air weight of the riser. The discussion raises concerns about how the riser's potential buckling under upforce affects buoyancy, questioning whether this contributes to the overall buoyancy force. It is clarified that the apparent weight of the riser is determined by the weight of the displaced water, calculated using the submerged volume. The buoyancy force ceases to act on the area where the riser is latched to the existing pipe.
mhl
Hi
I've got a scenario and would like a confirmation or rejection on it's correctness.
If i lower a steel riser (for simplicity it is 3000 m and vertical, open ended, cylindrical steel pipe, completely flush) into drilling mud (assume water) the surface weight would be the steel weight in mud. When I set the riser down (say i latch it on to an existing riser that is already in place with top at ~3000m), the weight of the riser at surface immediately becomes the air weight of the riser when it latches.
Correct??
In reality the steel would buckle a bit by the upforce before beeing latched and even more so when it is latched and surface pulling reduced to zero so the whole string rests on itself (far fetched, but example purpose). How does this affect the buoyancy force on the steel pipe?? does it contribute to the buoyancy force acting on the riser??
Honestly, I am not following the terminology that you are using. What do you have that is 3 km in length? What do you mean by "latching?" Can you do a diagram?
Anyways, the apparent weight is going to be the weight out of water - the weight of the displaced water. So, take the amount of the riser that is under water and calculate that volume. Use that volume and the weight density of water to calculate the buoyant force.
Hi. sorry for the oil terms. here's to simplify:
3000 m stell jointed tube, flush on outside and inside and open ended (no bottom, and might in real life be 9 5/8 inch in outside diameter, far fethced that it is vertical though) beeing lowered into a drilled hole and latched (screw onto an exciting in place pipe of same type about 3000 m into the hole.
Becuase buoyancy upforce acts on casing from below, would this not stop to act on this area when it is set down (latched, or screw) on the steel tube already in place??
hope this is more clear...(?)
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
