GR Lie Derivative of metric vanish <=> metric is independent
binbagsss
How to show that lie deriviaitve of metric vanish ##(L_v g)_{uv}=0## <=> metric is independent of this coordinate, for example if ##v=\partial_z## then ##g_{uv} ## is independent of ##z## (and vice versa)
2. Relevant equation
I am wanting to show this for the levi-civita symbol as the connection i.e. metric compatability were we have ## \nabla_{a}g^{uv} =0 ## so the first term of ##(L_v g)_{uv}=0## vanishes trivially.
[/B]
##(L_ug)_{uv} = U^{\alpha}\nabla_{\alpha}g_{uv}+g_{u\alpha}\nabla_vU^{\alpha}+g_{\alpha v}\nabla_u U^{\alpha}## (1)
If the metric is independent of some coordinate, e.g ##z## then we have ## \partial_z g_{ab} =0## but , assuming metric compatibility ##\nabla_{\alpha}g_{uv}=0## anyway, so there's no need to split it up into the partial and connection term, which seemed to me the most obvious way and only way I can see to substitute the information of metric independence of (say) ##z## into (1)
So we have ##(L_ug)_{uv} = g_{u\alpha}\nabla_vU^{\alpha}+g_{\alpha v}\nabla_u U^{\alpha}##, where there are no derivatives on the metric in these two terms, so I'm pretty stuck..
Many thanks
This is not so in general. You can have metric invariance along a vector which is not in one of the coordinate directions. The metric of an ordinary sphere is a example.
So, you should try to show that vanishing of the Lie derivative of the metric along a vector ##\Rightarrow## metric is invariant along that vector.
First of all, the Lie derivative does not involve the connection, so it's actually the case that:
(L_U g)_{\mu \nu} = U^\alpha \partial_\alpha g_{\mu \nu} + g_{\mu \alpha} \partial_\nu U^\alpha + g_{\alpha \nu} \partial_\mu U^\alpha
The first term doesn't vanish in general (although the corresponding expression involving the covariant derivative does: U^\alpha \nabla_\alpha g_{\mu \nu} = 0)
Now, let's look at the special case where U is a coordinate basis vector, e_\lambda, that means that U^\lambda = 1 and U^\alpha = 0 if \alpha \neq \lambda. So for this particular choice of U, \partial_\mu U^\alpha = \partial_\nu U^\alpha = 0. So we have:
(L_U g)_{\mu \nu} = \partial_\lambda g_{\mu \nu} + 0 + 0
Likes binbagsss
perfect, thank you
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
