GR Metric Meaning: Unpacking Confusion
  • Thread starter speeding electron
  • Tags
    Gr Metric
In summary: The Schwarzschild metric is an invariant under transformations, which means that the coordinate time t, defined as the time measured by an observer who is in a region of spacetime so far away from the object that spacetime there can be considered flat, is the same for all observers. The coordinate time is a very convenient way to standardize coordinate systems, since it is independent of the path that an observer follows. In fact, given the path that a particular observer is taking through space-time, the more physical observed proper times can be derived from the coordinate times. But one must specify the path to be able to perform this calculation."
  • #36
Sorry for the confusion, you are right. It is contraction and the indices must be upstairs and downstairs. I've seen things like Ricci = Tr Riemann meaning to contract the first and third indices or what ever convention one is using. I guess one should write Ricci = Con Riemann, but I've never seen it. At least I didn't use "Spur"
Pete, yes I 'd like a copy of Ohanian's paper, if it is not too much trouble. I mentioned this thread to a friend and he said there is nothing local about the curvature ! I exploded with: "The whole point of curvature was that the rotation of a vector parallel transported around a small arbitrary loop was given LOCALLY by the curvature tensor" He responded with: "It depends on second partials of the metric and that's non local" In reply to "Wadayamean?", he pointed out that you can't MEASURE curvature at a point. It requires the separation of neighbouring geodesics and that occurs over a small region and not at a point. The mathematical notion of local is "at a point". The physicist's idea of local is "in a small neighborhood" To sum up: the Curvature tensor is well-defined at each point and changes little over a small neighbourhood and is measured by geodesic separation (or vector rotation around a loop, etc) over this neighbourhood. Does this help or merely add more confusion?
  • #37
It's on the way. Check your e-mail. I sent 3 articles. One is Ohanian's article. The other is a criticism of Ohanian's article by Walstad. The last is Ohanian's response to Walstad.
Yep. Been there, done that. I had the same argument with other people too.
That is entirely an incorrect statement.
He's showing that he thinks that local means at a single point where in fact the term local, as the term is used in differential geometry, refers to something in a small neighborhood. In fact recall the definition as given in Differential Geometry, by Kreyszig
(page 2) local – A geometric property is called local, if it does not pertain to the geometric figure as a whole but depends only on the form of the configuration in an (arbitrarily small) neighborhood under consideration
The author actually gives an example stating "For instance, the curvature of a curve is a local property." which readily extends to Riemann curvature as being a local property referring to a small neighborhood. Therefore since derivatives are defined in a limit in small region and not with regard to a single point only it follows that "local" applies to a point and "nearby" surrounding points.
Exactly. Bravo.
Sorry but I have to disagree with that assertion.
I wasn't confused in the first place. I was merely pointing out that this point is the subject of debate in GR.
Pete
  • #38
Thanks Pete, I'll check for the papers on Monday at the office.
I'm surprised at Kreyszig. A derivative senses changes at nearby points and can't be found without knowing what goes on at the nearby points, but it lives at a specific point. His notion of local seems to be in contrast with global. Live and learn.
  • #39
Kreyszig is doing the typical thing - He's speaking about what is normally considered "local" in mathematics, i.e. an [itex]\epsilon[/itex] neighborhood. An [itex]\epsilon[/itex] neighborhood is not a global region. How else could anything be a local property? A propertys is not something a point on a curve has.
This is not unique to Kreyszig. See -- http://mathworld.wolfram.com/Local.html
In the end what really matters is what an author means by "local" when they use it. But its nice to stick to well defined terms rather than to redefine terms to fit our ideas of them.
How would you define local property?
Pete
  • #40
Now I'm confused I always though that local was defined in the limit.
  • #41
Same here.
If anyone finds a mathmatical sourc/text which states otherwise please let me know.
Pete
  • #42
Pete
The property lives at the point but depends on the neighbourhood. The derivative from first year calculus is the paradigm.
