A GR to Naive Physics: Is it Possible?
  • A
  • Thread starter Thread starter Simon Bridge
    Gr Phyiscs
Simon Bridge
I get asked a lot of questions like "what is the gravitational field due to xyz curved spacetime" ... and I don't think the concepts match well the way the querant is thinking.
However, I was wondering if there is a sort-of way to get to something like that.
I would normally think of a gravitational field as the potential energy function in some coordinate system ... that would be, the amount of work has to be done to get a test mass from at rest at some (reference) place to at rest in another place.
There's a way to work that out from GR and I forget ... it's the sort of thing that used to be given to students to show why it is problematic and not all that useful. Still, if going to use GR to do something in real life, you want to know how much energy will be needed to do something like change orbits. So it's doable.
I thought rather than figure it out myself, ask to see if there is a shortcut for common situations other people know about, or if there is a resource set up for this style of thinking.
Am I making sense?
This works, but only in a restricted class of spacetimes, the stationary spacetimes. A stationary spacetime has a timelike Killing vector field, and you can treat each of the integral curves of that timelike KVF as labeling a "point in space", and the norm of the timelike KVF along each integral curve is the "potential energy" at that point in space. Then everything works just as you describe.
However, there are many spacetimes of interest which are not stationary; the most commonly used ones are the FRW spacetimes of cosmology. In a non-stationary spacetime, there is no well-defined "potential energy", so what you describe does not work.
Likes Simon Bridge and vanhees71
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
