Grade Calculator: Find GPA & Subject Grades
  • Thread starter Thread starter smiley4080
A user is seeking assistance in creating a grade calculator that determines the necessary grades for achieving a specific GPA based on credit hours for multiple subjects. The example provided involves aiming for a 3.7 GPA with three subjects having different credit hours. Responses highlight the need for understanding weighted averages and mention the existence of multiple grade combinations that can yield the desired GPA. A Diophantine equation is referenced to illustrate the complexity of finding integer solutions for grades. The discussion emphasizes the importance of grading granularity in determining possible grade combinations.
smiley4080
Hello ,
I need some help>>>
I try to make Grade Calculater The student must enter his expected GPA and the number of credit hours than the calculator must find the grade (e.g A,B+,B,...etc) in each subject
for example if I want to get 3.7 in this semester and I took 3subject with 3,4,8 hours respectively what's the grade that I must get in each.
I try to find an equation that will help me
but I get fail because I try manythings and many equation and formula but nothing work
So can you please help me?
Thanks
Mathematics news on Phys.org
3.7 in each will work as will anything that give a 3.7 average. Do you not know how to take a weighted average?
There is no ONE answer but a multitude of combinations.
Assuming that grades in each class are integer values, then you have the Diophantine equation
30x+ 40y+ 80z= 555. x= y= z= 3.7 is not a valid solution but there still may be many solutions.
Very good point. I was assuming fine granularity in the grading system, which of course may not be the case. smiley4080, the number of solutions will go up as the granularity of the grading system becomes finer. Probably I should say that the number of solutions will LIKELY go up as the ... since it COULD still be possible that there is only one combination. Clearly if the granularity is .1 points, then you can have 3.7 in each.
I know it me there are many possible answer but I need other formula which I used
I used the formula of how to get GPA to get one of possible answer but I thing is not correct way
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
