Gradient and mean value theorem
6 replies · 5K views
brad sue
Hi
please , can someone help me with this problem.
I need to know the procedure.
Let f(x,y)=x^3-xy. set a(0,1) and b(1,3).
Find a point c on the line sement[ab] for which
f(b)-f[a]= gradient(f[c]) * (b-a)
Thank you
B.
brad sue said:
Hi
Thank you
B.
The "procedure" is to calculate everything you can there, then solve the equation for c. Since a= (0,1), f(a)= f(0,1)= 0^3- 0(1)= 0. Since b= (1, 3), f(b)= f(1,3)= 1^3- 1(3)= -2. f(b)- f(a)= -2- 0= -2.
I'm not particularly happy with the notation on the right side! a and b are points but you have to treat "b-a" as a vector subtraction: b- a= i+3j- (j)= i+ 2j. grad f= (3x- y)i- xj. Now that product "*" is a dot product:
grad f*b-a= ((3x-y)i- xj).(i+ 2j)= 3x-y- 2x= x- y= -2.
That's one equation for two unknown values, x and y. To get the other, use that fact that c= (x,y) is on the line between a and b. One way to do that is to write the line between a and b ((0,1) and (1,3)) as y= 2x+ 1 (do you see how I got that?) and solve the two equations x- y= 2 and y= 2x+ 1 for x and y. Another is to write parametric equations for the line: since b-a= i+ 3j, x= t, y= 2t+ 1. Replace x- y= 2 with those, solve for t and use that value of t to find x and y.
Where did you find the solutions for this? I'm writing a paper and struggling to find info for use!
I guess I'm confused as to how you learned this. I couldn't find a lot of stuff online about it. As I said I'm working on a project involving this and I can't find anywhere to learn this stuff.
I just copied what you wrote and I'll write comments in red of where I'm confused.
I'm not particularly happy with the notation on the right side! a and b are points but you have to treat "b-a" as a vector subtraction: b- a= i+3j- (j)= i+ 2j. grad f= (3xshould this be squared?- y)i- xj. Now that product "*" is a dot product:
How do you know that x-y=-2??
Why is x-y=2 now?
Yes, that was, I hope, a typo on my part.
I just made a really dumb mistake! The derivative of [itex]x^3- xy[/itex] with respect to x is [itex]3x^2- y[/itex], not "3x- y"! I hope thoat was just a typo on my part and I am not really losing my mind.
Now [itex]grad f\cdot(b-a)= (3x^2- y)\vec{i}- x\vec{j})\cdot(\vec{i}+ 2\vec{j})[/itex][itex]= 3x^2- y- 2x[/itex] and that must be equal to -2: 3x^2- y- 2x= -2.
Why is x-y=2 now?
That was the mistaken equation I got before. It should be [itex]3x^2- y- 2x= -2[/itex]
So [itex]3x^2- y- 2x= 2[/itex] and y= 2x+1. Replace y in the first equation by 2x+1 and we have [itex]3x^2- 2x-1- 2x= -2[/itex] or [itex]3x^2- 4x+ 1= 0[/itex]. By the quadratic formula, the roots of that are
[tex]\frac{4\pm\sqrt{16- 9}}{6}= \frac{4\pm\sqrt{7}}{6}[/itex].<br /> <br /> Since 7 is just a little less than 9, [itex]\sqrt{7}[/itex] is just a little less than 3. If we were to take the positive, we would have [itex]4+ \sqrt{7}[/itex] a little bit more than 7 and [itex](4+ \sqrt{7})/6[/itex] a little bit larger than 1. If we take the negative, we have [itex]4- \sqrt{7}[/itex] a little smaller than 1 and [itex](4-\sqrt{7})/6[/itex] between 0 and 1. In order that (x,y) be between (0,1) and (1,3) x must be between 0 and 1 and so [itex]x= (4- \sqrt{7})/6[/itex]. Then, of course, [itex]y= 2x+ 1= (4- \sqrt{7}}/3+ 1= (7- \sqrt{7})/3[/itex] which is a little larger than 1 and so between 1 and 3.[/tex]
