Gradient of a time-dependent potential energy
The discussion centers on the gradient of a time-dependent potential energy defined as U = cos(θ(t)) H(t), where H is a time-dependent magnetic field. There is uncertainty regarding whether the second term in the gradient expression should be included, as it raises questions about the dependence of H on position. It is noted that potential energy typically depends on state variables, and if an external agent alters the potential landscape, it can introduce non-conservative forces and torques into the system. The complexity of the problem is acknowledged, emphasizing the need for clarity in defining the system and its variables. The conversation also touches on the importance of using the appropriate gradient operator in different coordinate systems.
kuntalroy
Say, we have potential energy of the form U = cos (\theta(t)) H(t).
H denotes a magnetic field that is time-dependent and it's an input variable to the system. Now when you take gradient of potential energy, would you write
\nabla U = \left[ - sin (\theta(t)) H(t) + cos (\theta(t)) \frac{\partial H(t)}{\partial \theta(t)}\right] \hat{e}_{\theta} = \left[ - sin (\theta(t)) H(t) + cos (\theta(t)) \frac{dH(t)/dt}{d\theta(t)/dt}\right] \hat{e}_{\theta} ?
Should the 2nd term be present?
Mathematics news on Phys.org
this doesn't totally make sense to me - is the potential only a function of theta or does H vary with position?
also if you want to take the gradient in cylindrical or spherical coords, you have to account for the basis vectors changing, and so use the form of the gradinet operator in those coordinates
Well, theta is a state variable while H is a input variable. Usually, the potential energy U is a function of only the state variables - (r,theta,phi) - in spherical coordinate system - for the simplified case it's only a function of theta. It's valid for only a 'closed' system.
If some external agent modifies the potential landscape and does an energy exchange in time, it gets coupled with the dynamics of the system - here it's theta. This can be produce an additional non-conservative field and subsequently a torque. This may have a self-consistent nature with the dynamics of the system.
This is not a straigtforward problem - first we have catch the problem - and providing a solution would not be straigtforward at all.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
