Graph of frictional force vs angle of inclination
The discussion focuses on plotting the graph of frictional force against the angle of inclination for a mass on an incline. The maximum static friction occurs at the angle arctan of the coefficient of friction, with the friction force being proportional to sin(θ) for angles less than this and proportional to cos(θ) for angles greater than it. When the incline exceeds the maximum angle, kinetic friction takes over, causing the frictional force to decrease with increasing angle due to the reduction in normal force. The participants agree on the mathematical relationships governing these behaviors and emphasize the importance of indicating these changes in a graph. A request for assistance in graphing the data using arbitrary values is also made.
jontyjashan
Our teacher had asked us to plot graph of frictional force acting on a given mass kept on an incline vs its angle of inclination .i made a graph where the max frictional force was at angle arctan u(coefficient of friction ) . The graph of friction at angle less than arctan u was proportional to sinx(angle of inclination ) and the graph greater than arctan u was proportional to cosx. Am I right,
Yeah, that seems right. In the regime where static friction applies and the block remains motionless, friction provides whatever force is required to keep the block from sliding. In other words, the friction force is equal (in magnitude) to the component of the block's weight that is parallel to the incline:
F_f = mg\sin\theta
where theta is the angle of the incline. But there also is a maximum possible static frictional force:
F_f \leq \mu_s F_N = \mu_s mg\cos\theta
where FN is the normal force. Therefore, the largest inclination at which the block won't slide is the inclination at which the required frictional force (left hand side of equation below) is just equal to the max available frictional force (right hand side below):
mg\sin(\theta_{\textrm{max}}) = \mu_s mg\cos(\theta_{\textrm{max}})
\mu_s = \tan(\theta_{\textrm{max}})
\theta_{\textrm{max}} = \arctan(\mu_s)
So I also agree with you there. Above the maximum inclination angle, we are in the regime of kinetic friction, since the block has begun sliding (the friction force is no longer enough to balance the component of the weight parallel to the incline). In this case, the frictional force becomes:
F_f = \mu_k F_N = \mu_k mg\cos\theta
and now we have cosine-dependence on theta, rather than a sine-dependence. This is significant, because it means that the frictional force actually diminishes with increasing angle (due to the diminishing normal force), which is the opposite trend from before in the static regime, where the higher the angle was, the higher the friction became to prevent sliding (up to a limit). Note also that the constant of proportionality is different here, since you now have a factor of \mu_k in front. You'll probably want to indicate that on your sketch.
Thanks. Explanation was really good. Can you make a graph of this using calculators. I was not able to do so. Take any arbitrary values of theta, mass and friction coefficient . It would really help.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
