Gravitation as varying density of a space-propertime manifold?
bcrelling
Originally I asked on another thread whether the GR effects on light can be described as light passing through a medium of varying density- so exerting its effects by refraction.
A.T. kindly posted the following links:
http://www.newscientist.com/article/dn24289#.UlsOR-B3Zmh
http://www.nature.com/nphoton/journal/vaop/ncurrent/full/nphoton.2013.247.html
However his the post was erased(I can only assume for necroposting as Nature Photonics is peer reviewed).
The links seem to confirm my original suspicions that the gravitational effect on light is caused by refraction, and A.T. suggested this medium would be varying densities of "space-proper time".
Does anyone have issues with this explanation as it is much simpler to understand and would be a useful teaching aid if it were correct?
How many issues would you like to see? The first one is a general philosophical objection to "simpler models that are easier to understand." This usually means trying to explain relativity or quantum mechanics in classical terms. So we pretend that gravity causes an index of refraction, and avoid thinking about all that curved space stuff. :wink: But the problem with simplistic models is that they get taken too seriously. Every model has limitations. Soon the limitations get overlooked. People start to think it's the index of refraction of some real substance. Causing more puzzlement than if they had learned about the curved space stuff to begin with.
Ok, other objections. This is an ancient idea, but to make the model at all plausible, the index of refraction at a point should be the same in all directions. That is, you need to use isotropic coordinates. First you will have a hard time explaining why the speed of light we measure in the lab is c, even though n here on Earth is greater than 1.
What happens to the value of n when you perform a Lorentz transformation?
Next, a static metric in isotropic coordinates has two independent functions, gtt and grr. You're replacing them with one function n(r), and this represents a loss of information. In other words, you'll be able to choose n(r) to fit the light deflection, but not other effects. In particular, I believe you'll get the wrong answer for the Shapiro delay.
At the surface of a black hole, which is a stationary null surface, you'll need to let n go to infinity.
And for a rotating solution like Kerr, you won't be able to use this idea at all. The light paths in Kerr depend on whether you're going clockwise or counterclockwise, and one index of refraction won't suffice to explain both.
Likes 1 person
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
