Gravitation Problem, velocity of object on impact
The discussion focuses on calculating the impact velocity of an object falling toward Earth from a distance of 8 x 10^7 m with an initial velocity of 2000 m/s. Participants suggest using conservation of energy principles rather than direct integration due to the changing gravitational force. The gravitational force is treated as conservative, allowing for simplification in calculations. One contributor clarifies the potential energy considerations, emphasizing that the mass cancels out in the energy equations. Ultimately, the correct approach involves applying the conservation of energy formula to determine the final velocity at impact.
rzwhipple
Object is moving directly toward earth
initial V = 2000 m/s
distance from center of Earth = 8 X 10^{7} m
Determine speed at impact
g = \frac{GM}{R^{2}}
I am guessing I'll need to integrate to get velocity, but am not sure how to proceed. If I integrate with respect to t, what do I do about the R variable which is also changing?
This problem is probably from a Chapter dealing with potential energy functions, where the integration has already been done, to determine the potential energy function. The gravitational force, between these two objects is a conservative force, so all you'll need is conservation of energy, at an initial (i) and final (f) position. Draw a nice picture of this collision, and you won't make any errors for rinitial and rfinal.
Ahh, thanks this worked nicely, I didn't use the formula for energy since you need both masses, but problem does say to neglect drag so the pot energy is the same initial and final, and mass of the object was in every term so that dropped out. Thanks again!
This doesn't sound correct. The initial position is, according to the numbers you gave,
\rm r_{initial} = 8 X 10^7 m = \frac{8 X 10^7 m}{6.37 x 10^6 m} R_E = 12.6 R_E , so there is no way that Uinitial = Ufinal.
Maybe I was unclear, here is what I did:
\frac{1}{2}mV^{2}_{I} - \frac{GmM}{R_{I}} = \frac{1}{2}mV^{2}_{F} - \frac{GmM}{R_{F}}
V^{2}_{I} - \frac{2GM}{R_{I}} = V^{2}_{F} - \frac{2GM}{R_{F}}
V^{2}_{F} =V^{2}_{I} - \frac{2GM}{R_{I}} + \frac{2GM}{R_{F}}
V_{F} = \sqrt{V^{2}_{I} - \frac{2GM}{R_{I}} + \frac{2GM}{R_{F}}}
plug and chug, voila--you definitely had me on the right track, however, and I think I forgot to mention we were to neglect drag, so therefore energy is conservative--thanks again
