Does the Medium Affect Gravitational Constant G?
The gravitational constant "G" remains unchanged regardless of the medium it passes through, as any potential effects would be too weak to detect. Unlike light, which can be attenuated by materials like glass, gravity does not exhibit similar properties. While gravitational attraction can be influenced by the arrangement of mass, this does not equate to a reduction in gravity akin to dielectric polarization. The discussion clarifies that gravitational effects are fundamentally different from electromagnetic interactions. Overall, the medium does not affect the gravitational constant in any significant way.
yaseen shah
why does the meduim does not affects gravitational constant "G"
I think you are asking about some sort of attenuation effect on gravity passing through a medium (like speed of light through glass)?
We wouldn't be able to tell if it did. It's incredibly weak so any effects would be virtually undetectable.
If you are comparing it to the dielectric susceptibility, then there is a similar effect of course. Gravitation will move objects so objects even further away will experience a modified attraction due to the rearrangement of objects.
But this is no negative gravitation, so you don't get the equivalent of the polarisation effect for dielectrics.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
