Gravitational force = 0 between two planets?
The discussion revolves around a physics problem involving gravitational forces between a planet and its moon. An object is positioned between them such that the net gravitational force acting on it is zero. The equation M/d^2 = m/(R-d)^2 is derived to find the distance d from the planet's center. The participants confirm that the approach is correct and suggest solving the resulting quadratic equation to find the value of d. The focus remains on applying gravitational equations to determine the object's position accurately.
Which is the answer?
  • ((M-m)/(M+m))R
    Votes: 0 0.0%
  • (M+m)/(M-m)
    Votes: 0 0.0%
  • (((M^.5)+(m^.5))/(M-m)) * (M^.5) R
    Votes: 0 0.0%
  • (((M-m)/(M+m))^.5) * R
    Votes: 0 0.0%
  • (((M^.5)-(m^.5))/(M-m)) * (M^.5) R
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Hayden_
A planet of mass M has a moon of mass m in a circular orbit of radius R. An object is placed between the planet and the moon on the line joining the center of the planet to the center of the moon so that the net gravitational force on the object is zero. How far is the object placed from the center of the planet?
Fg=G(Mm/R^2)
I used the variable d to describe how far the object is placed from the center of the planet
G(M(mass of object))/d^2 = G(m(mass of object))/(R-d)^2
G and mass of object cancel out
M/d^2 = m/(R-d)^2
find d.?
Looks good to me!
Hi Hayden! Welcome to PF :smile:
Hayden_ said:
M/d^2 = m/(R-d)^2
Looks good to me!
Now all you have to do is to solve the quadratic equation … :smile:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
