What does the "r" in the formula F = - GMm/r^2 mean?
In summary: I think the confusion came because I was not careful enough about | \vec{dr} | . Then, the integral becomes W = - \int_{r_i}^{r_f} G m M /r^2 ~ (-dr) = G m M [ 1/r_i - 1/r_f ] Evaluating this between the initial and final positions gives a positive answer because 1/r_f is larger than 1/r_i .I hope this is more understandable.
Miraj Kayastha
80
Does it mean distance between the two bodies or the radial displacement ? Is the "r" a vector or a scalar?
How do you square a vector? By scalar product with itself? Then it doesn't matter.
"dr" is used when potential energy is derived from integration. Here is dr a small displacement in the direction of r?
To calculate the work done by gravity using integration when a body if falling is dr positive or negative?
##dr## is infinitesimally small. This allows the value of ##F(r)## to change from one point to the next along ##r.##
You have to be a little careful about interpreting the sign of the formula you show above:
If for example, you define ##r## to be positive pointing from the big ##M## to the little ##m##, then ##F(r)## in your formula is the force exerted on little ##m## in the ##-r## direction (toward big ##M##), and therefore ##F(r)## has negative sign.
Following the same convention, "falling" means moving toward ##M##, so ##dr## is also negative. Hence ##\int W = \int F dr > 0##, i.e., gravity is exerting force in the same direction as the travel, hence it is doing positive work.
'r' is the distance between the two bodies at a given instant. Since this is a "static" rather than "dynamic" equation, there is NO motion and so no "radial displacement".
r, as used here, is a scalar, the distance between the two objects. If [itex]\vec{r}[/itex] is the vector from one body to the other, then [itex]r^2= \vec{r}\cdot\vec{r}[/itex] or, equivalently, [itex]r^2= ||\vec{r}||^2[/itex].
Since the direction of the gravitational force on a body is toward the other, we can write this as a vector equation by multiplying by the unit vector from one body to the other, [itex]\frac{\vec{r}}{r}[/itex]:
[tex]\vec{F}= -\frac{GMm}{r^2}\frac{\vec{r}}{r}= -\frac{GMm\vec{r}}{r^3}[/tex]
If dr is negative in case of a falling object, the integration gives a negative result since the lower limit will be greater than the upper limit. So, what's wrong?
I think it can cause confusion to talk about a negative "dr" since there can be confusion with [itex] \vec{dr} [/itex] (which cannot be "negative") and with [itex] |\vec{dr}| [/itex] (which cannot be negative either!).
Here is another way to present this: the work is
[tex] W = \int \vec{F} \cdot \vec{dr} [/tex]
Now, as an object is falling straight down, the force and the displacement vectors are in the same direction, therefore the dot product is positive and simply equal to [itex] |\vec{F} | \, |\vec{dr}| [/itex]
Now, after integrating, you get [itex] - G m M /r [/itex] (the sign comes from the integration).
CORRECTION: I forgot to mention that since the value of r is decreasing position is decreasing, there is an additional minus sign that we must incorporate. The rest of my post is unchanged.
Evaluating this between the initial and final positions gives a positive answer because [itex] 1/r_f [/itex] is larger than [itex] 1/r_i [/itex].
You're right, talking about negative dr is confusing. The way I think about it is that dr is negative because the integration is from high to low. But…yeah.
I agree that expressing the integral using the dot product is best. I was just trying to avoid explaining the dot product. :smile:
I am still not clear about the integration because the work done by a variable force is ∫F.dx where dx is a very small DISPLACEMENT.
Whereas while calculating the work done by the gravitational force we do ∫F.dr where dr is a radial displacement that is always outwards. So is dr equal to dx? I mean dr is not the displacement if a body is falling, right?
I am sorry, I forgot to mention an important point in my previous post (which I corrected). Let me be more clear.
We have
[tex] W = \int_{r_i}^{r_f} \vec{F} \cdot \vec{dr} = + \int_{r_i}^{r_f} | \vec{F} | ~ | \vec{dr} |
[/tex]
Now, [itex] | \vec{F} | = G m M /r^2 [/itex]
We must be careful with [itex] | \vec{dr} | [/itex]. We need to relate this to [itex] dr [/itex], which is the change of value in the coordinate r. As Olivermsum correctly mentioned, since the value of r is decreasing, the change of coordinate in r is negative so [itex] | \vec{dr} | = - dr [/itex].
So putting everything together, we get
[tex] + \int_{r_i}^{r_f} | \vec{F} | ~ | \vec{dr} | = - \int_{r_i}^{r_f} \frac{G m M}{r^2} dr [/tex]
Doing this integral, we get
[tex]
+ \frac{G mM}{r_f} - \frac{GmM}{r_i} [/tex]
And this is positive because [itex] r_i > r_ f [/itex]
r is the distance between the centers of the two objects which are assumed to be either point particles or spherical particles. For weirdly shaped objects, you can take r to be the distance between the centers of mass, but the equation "F = - GMm/r^2" is only approximately true for this case. The approximation is good if the distance r is large compared to the sizes of the objects and/or the objects are almost spherically symmetric in mass distribution.
We have
[/tex]
[tex]
Why did you put the magnitude of force, shouldn't it contain minus sign as well? Because F is in opposite direction to r?
I read a post online that said if we state -dr we are already assuming the motion of the body is downwards so the limits should be switched and if we state dr then only we can keep the initial value on the lower limit and final value at the upper limit because if we keep dr positive then the limits determine the direction of motion rather than the dr?
Is this true?
The article I read : http://www.wired.com/2012/03/deriving-the-gravitational-potential-energy/
Also, is the derivation of GPE different for falling and rising objects different because in falling dr is negative whereas in rising dr is positive?
1. What does the "r" stand for in the formula F = - GMm/r^2?
The "r" in this formula represents the distance between two objects. This can be the distance between a planet and the sun, or between any two objects that are interacting with each other through gravitational force.
2. How is "r" related to the force of gravity?
The force of gravity is inversely proportional to the square of the distance between two objects. This means that the farther apart the objects are, the weaker the force of gravity between them will be. The "r" in the formula represents this distance and is squared in the denominator to account for this inverse relationship.
3. Can "r" be negative in this formula?
No, "r" cannot be negative in this formula. Distance is always a positive quantity, and the negative sign in the formula is used to represent the attractive nature of the force of gravity between two objects. The negative sign is also used to indicate that the force is always directed towards the center of mass of the larger object.
4. How does changing the value of "r" affect the force of gravity?
As mentioned earlier, the force of gravity is inversely proportional to the square of the distance between two objects. This means that as the distance between two objects increases, the force of gravity between them decreases. Conversely, if the distance between two objects decreases, the force of gravity between them increases.
5. Why is "r" squared in the formula?
The "r" is squared in the formula to account for the inverse relationship between distance and force in the calculation of gravitational force. This ensures that the force of gravity decreases at the appropriate rate as the distance between two objects increases.
  • Other Physics Topics
