How to Calculate Escape Speed Using Newton's Gravitational Law
  • Thread starter Thread starter mitch_nufc
    Gravitational Law
The discussion focuses on calculating escape speed using Newton's Gravitational Law, specifically the equation z'' = -gR^2 / (z + R)^2. The user successfully transformed the second derivative into a first-order equation and derived the expression v^2 = (2gR^2)/(z+R). However, they overlooked the integration constant and the definition of z, which is crucial for establishing boundary conditions. The correct interpretation of z as the distance from the surface of the Earth is essential for accurate calculations.
  • Understanding of Newton's Gravitational Law
  • Familiarity with differential equations
  • Knowledge of integration techniques
  • Basic physics concepts related to escape velocity
  • Review the concept of escape velocity in classical mechanics
  • Study the application of the chain rule in differential equations
  • Learn about boundary conditions in physics problems
  • Explore numerical methods for solving differential equations
Physics students, mathematicians, and engineers interested in gravitational physics and escape velocity calculations.
mitch_nufc
An object is fired vertically upwards from the surface of a planetary body; it moves under the action of Newton’s Gravitational Law, without
resistance, so the equation is z'' = -gR^2 / (z + R)^2 . Find the relation between v = z' and z and use this model, and the relation that you have
found, to obtain a numerical estimate for the escape speed on the surface of the Earth.
What I've done so far is transformed z'' to vz' using the chain rule.
Next vz' = f(z)
=> 1/2*v^2 = int( f(z)dz + C )
now solve v(z) = dz/dt
=> int (dt) = int(1/v(z)dz)
So I got (gR^2)/(z+R) = (v^2)/2
(2gR^2)/(z+R) = v^2
This is where I got and I don't know where to go next, I don't even know if it's right? Could someone attempt this for me please? Thanks
You arrived at the right expression, however you ignored the integration constant. How is z defined, is it the distance from the surface to the Earth or from the center of the earth? Looking at your formula I would guess from the surface of the earth. This would give you a boundary condition v(0)=0.
