dontdisturbmycircles said:
I don't know why you would choose the forum feedback section to post this in...
but, no they are not the same. One is weight, one is mass. Mass never changes, but your weight (I wouldn't call it gravitational mass) (expressed in Newtons) changes according to the strength of the gravitational field you are in. Mass can be measured in inertial mass since even if truck is "weightless" in space, you would still have to do work on it to move it, hense inertial mass.
Nono, this is not what is understood by "inertial" mass, and "gravitational" mass. Gravitational mass is not "weight", which is what you are talking about.
There are *in principle* 2 different kinds of mass (actually, 3, but hey, let's keep it simple).
There is the mass "m" in Newton's second law: m.a = F, or, in other words, the m in the formula for momentum: p = m.v. This is "inertial" mass. It is the constant of proportionality between the applied force (supposing we know that somehow, and we are not running in circles, but that's another debate...), and the acceleration of the object. You need this m in any form of dynamics. For instance, imagine that in the world, there is only Coulombic interaction, then the force between two particles would be given by:
F = q1.q2/(4 pi eps0 r^2), and if you fill in this force into Newton's equation, you have to do: m.a = F. The m in that equation is the inertial mass, and the q1 and q2 are the electric charges of the particles.
But Newton also discovered a specific interaction: gravitation. The force of gravitation, according to Newton, takes on a similar form as the one for electrostatic attraction:
F = -G.M1.M2/r^2
Here, G is Newton's gravitational constant (like the 1/4 pi eps0 for electrostatics), and there's a minus sign which makes it opposite in action to electrostatics. M1 and M2 are the "gravitational charges" of the two bodies.
This "gravitational charge" is what one calls the "gravitational mass". Now, one isn't used to say that, because of a principle:
"the gravitational charge equals the inertial mass"
In other words: M1 = m1.
The number entering in the formula for gravitational interaction, M1,
is the same number, than m, the number that enters in Newton's second law, m.a = F
This didn't need to be so, in Newtonian gravity. But it is experimentally observed to be so. It is called
the principle of equivalence. If this principle holds, then there's no need in giving different names to M1 and m, and we call it simply "mass".
The principle of equivalence is the corner stone of Einstein's general relativity, because Einstein realized that, if inertial and gravitational mass are the same, that the "force of gravity" can be an entirely geometrical effect (and not a genuine force), because no property of the object proper is needed to determine the trajectory (which can hence be a "bending of spacetime" itself, and not simply a trajectory of a specific object, related to its properties).
EDIT: as far as I know, no deviation from the principle of equivalence has ever experimentally been observed...
