Gravitational or inertial mass gain in cern ?
Hadrons in the LHC gain mass as they approach relativistic speeds, resulting from the conversion of energy into mass according to E=mc^2. This increase in mass is primarily an increase in inertial mass, rather than active gravitational mass, which is too small to measure accurately. While their energy contributes to active gravitational mass, the gravitational effects of moving masses are complex and not simply a matter of increased mass. The hadrons do not reach the speed of light but come very close, only a few kilometers per hour away. The discussion clarifies that the mass gain is a result of energy conversion during high-energy collisions, not a transformation of existing mass.
Alex_P
Hi,
I have been reading about CERN for a while and found amazing - amongst many other things - the fact that hadrons in the LHC turn some of their energy to mass after having reached the maximum possible speed. However this statement was not clear enough. I was wondering whether the mass they gained was their Inertial or their Active Gravitational. Do they really get heavier or is it just an increase of their inertia?
Thank you in advance,
Alex
It's real mass. The result of E=mc^2 or m=Ec^-2.
As they approach the speed of light, the affect is enormous.
They increase their inertia, that is sure and easy to see. The active gravitational mass is far too small to measure it. According to GR, their energy is a contribution to active gravitational mass (in our lab frame), but the gravitational effect of moving masses is more complicated than a simple increase in mass.
They don't turn something into something else. In collisions, a fraction of their energy is used to create new particles.
That does not happen, but they are very close to the speed of light (some km/h away from it).
Thank you for your replies! You 've both been most informative!
I meant the hadron's maximum possible speed which is of course less than the speed of light.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
