Gravitational potential energy problem
The gravitational potential energy of a self-gravitating sphere, such as the Sun, is approximately -GM^2/R. The timescale for gravitational contraction to supply the Sun's current luminosity can be calculated using the formula t = -(1/2)(W_sun)/(L_sun). The virial theorem indicates that for self-gravitating bodies in equilibrium, the relationship T = -(1/2)V holds, allowing for energy calculations as the star contracts. This method was historically significant before the understanding of nuclear fusion processes. Understanding these principles provides insight into stellar evolution and energy generation.
Tuugii
The gravitational potential energy W of a self-gravitating sphere of mass M and radius R depends on the detailed distribution of mass within the sphere, but it is generally of order of magnitude -GM^2/R. For the Sun, W_sun = -2G(M_sun)^2/R. What is the timescale
t = -(1/2)(W_sun)/(L_sun) over which gravitational contraction could have supplied the power radiated by the sun at it's present rate?
please give some hints, thanks a lot.
I am giving some answer because I think the question belongs to the Advanced Physics section.
There is something called a “virial theorem” which holds good for self gravitating bodies and many other systems. If the system is roughly in equilibrium, so that the time averages of kinetic and potential energies are changing slowly, the virial theorem implies that T = -(1/2)V. As the star shrinks, the energy is radiated away so that the above relation is valid. So, knowing the present luminosity of the sun, we can roughly find how long it can radiate at the present rate using this mechanism.
In fact, this was the theory proposed before nuclear reactions were known about.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
